-   -   Tall Windows and Trim Problem (http://www.diychatroom.com/f14/tall-windows-trim-problem-61604/)
crutch 01-11-2010 02:36 PM
We are in the process of building a new house. There are a handful of 6' (or 72") windows in it. The windows are set at a 6'8" (or 80") height to be aligned with the doors.
The issue my builder is telling me we will run into is the apron on my window trim will be meeting my baseboard. I plan to trim my other smaller windows with simple 1x's. We plan to have a tall baseboard, approx 7.5".
So if you do the math, 80" height (top of the windows) minus 72" window size leave it 8" inches from the floor. This puts the window stool 8 inches from the floor and .5 inch from the baseboard.
What do you guys suggest?
Ron6519 01-11-2010 04:52 PM
You still need to put molding around the perimeter of the window. How wide are the 1x's?
Might make sense to get a smaller window so the two moldings aren't right on top of one another.
Ron
jlhaslip 01-11-2010 06:03 PM
raise the windows up a few inches. unless the windows and doors are on the same wall, it should go un-noticed.
allowing for the height of the door slab, an airspace under it (5/8" or 3/4"), and the door jamb header thickness when doing the calculations, the door will be above the 6'8" mark. that is the slab length. I use 82 1/2" for door cripple height above floor.
I cut the cripples at 82.5, sit it on the bottom plate (1 1/2")and fill under the header with a piece of wall thickness material to allow for a trim nailer at the header. this allows for some height adjustment depending on the floor finish and makes it easier to set the strike side of the jamb when installing the door. Many ways to frame and hang doors.
If you are just framing the wall right now, have the window headers positioned up under the top plate and fill in the underside of the header once you determine how to handle the window openings.
II Weeks 01-11-2010 07:29 PM
not knowing what windows your using but if theyre Anderons, the window is 1 1/4" thick o all sides, in other words, the window opening has to be 1 1/2" higher than the door opening to have the window jamb and the door jamb align.
Hard to say without seeing it. You could have a wider sill, as wide out as the baseboard and forget about adding on the apron piece or 3/4 corner molding over the jambs or rock, corner bead and spackle, no molding or .. .
like I said, without seeing, its hard to say.
hayewe farm 01-11-2010 09:05 PM
1 Attachment(s)
Take a look at this picture as you can see the area under the windows is framed to match the window trim and the baseboard terminates at the frame.
crutch 01-11-2010 10:06 PM
3 Attachment(s)
Here are some samples of what I am looking to do. I really wish I had closeups.
Italgrl 01-11-2010 11:58 PM
What's wrong with that? I've seen windows go very close to baseboard where only a tiny strip of paint separates the two.
I wouldn't think it's a problem, but you could always just reduce the base by .5" to increase the separation if you feel you must.
Or, increase the baseboard .5" so they meet.
CustomBuild 01-20-2010 10:33 PM
Bingo, heyewe. The portion under the window can be trimmed to look like a raised panel.
