Tall Oven Cabinet - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 02:54 PM   #1
Location: East of Marysville California in the foothills-Loma Rica
Tall oven cabinet
I have not built an oven cabinet before. the spec sheet on the oven i am building the cabinet for calls for the shelf it sits on to be able to hold 375 pounds. the cabinet will be 30" deep by 30" wide +/-. would 3/4" plywood dadoed and glued be sufficient for this or will i need some type of reinforcement?
jsteve846 is offline   Reply With Quote
Old 08-10-2010, 05:25 PM   #2
DIY staff
Rewards Points: 7,174
3/4 inch dadoed into the cabinet sides will be fine----Mike---
Old 08-11-2010, 10:58 AM   #3
Thanks for responding Mike. I was hoping that would be OK.
Old 08-11-2010, 08:58 PM   #4
another question. i don't see how a 24 1/2" unit will slip into a cabinet with a 24" depth. where can the wiring fit? is it better to make the cabinet as deep as possible, say 30", to give plenty of room behind the oven for wiring?
Old 08-12-2010, 05:36 AM   #5
DIY staff
oven cabinets are deeper than the base cabinets-- see if you can get a copy of the spec sheet for the oven
There is usually an open channel in the back of the oven so the wires can be dropped below the oven opening--into the bottom of the cabinet for hook up.
The Depot cabinet folks might give you the standard size for an oven cabinet.---Mike---
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Correct Material for Eye-level Oven Cabinet Bouraq Carpentry 4 02-05-2009 05:13 PM
Oven - junction box in cabinet DIYGST Electrical 5 11-13-2008 03:23 PM
how to move elec outlet in oven cabinet noodle Electrical 1 09-27-2008 07:40 AM
Wall oven smaller than Cabinet Space kdiangson Appliances 4 11-13-2007 09:21 PM
