Tall Baseboards That Run Into Kitchen Cabinets... What To Do? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 06:31 PM   #1
Rewards Points: 14
Tall baseboards that run into kitchen cabinets... what to do?
We've been putting in 5" baseboard in our house. At two different locations, the baseboard turns a corner into the kitchen and is going to end at a floor kitchen cabinet. The problem is, the doors of the cabinet(s) won't open if the tall baseboard continues to the cabinet because it will be in the way. The previous baseboard I guess was short enough to fit under the doors. I can take a picture if needed.
Anyways, what do I do? What do contractors and home builders usually do? I've never seen kitchen cabinets where the doors are 5+ inches off the floor. Surely this is a problem that people have run into before...
Should I cap off the baseboard before it reaches the cabinet? Two problems: 1. I think it will look odd. 2. Because we have 1" bullnose corner drywall, the hardwood floor will leave a small exposed opening at the corner because baseboard normally covers it.
I can take a picture if you need me to.
Jakobud is offline   Reply With Quote
Old 06-09-2011, 06:37 PM   #2
AfterDinnerDIY.com
A Picture would help.
AfterDinner is offline   Reply With Quote
Old 06-09-2011, 06:40 PM   #3
Rewards Points: 14
Old 06-09-2011, 06:40 PM   #4
KemoSabe
loneframer's Avatar
Funny you should ask. I just went back to a house I framed and trimmed several years ago. The homeowner let me get some pictures while I was there. Here is a very similar situation to yours and how I dealt with it in this case.
Tall baseboards that run into kitchen cabinets... what to do?-013.jpg   Tall baseboards that run into kitchen cabinets... what to do?-010.jpg
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 06-09-2011, 06:42 PM   #5
Rewards Points: 14
Regarding your trim, does that door have any problems opening? Like does it hit the baseboard? If you look in the pics I posted above, you can see that the doors will hit the baseboard as it's opening, so basically it won't open...
Old 06-09-2011, 06:47 PM   #6
KemoSabe
loneframer's Avatar
That's the entire reason why I went to all that trouble with that detail. The door would have bound on the base before fully opening.
Old 06-09-2011, 06:49 PM   #7
Rewards Points: 14
Ya I see now how you made the baseboard turn downward before going around the corner... I will have to go that route I think... Are there any other solutions to this problem?
Old 06-09-2011, 07:03 PM   #8
KemoSabe
loneframer's Avatar
It's possible that different hinges could be available that have a "throw" built into their design. It looks like you are too tight to even squeeze the base behind the door, so that idea is out.
Without physically moving the cabinet over and adding the proper filler on the side, the only other option I see is possibly modifying the door opening and ripping the door narrower to allow for the base.
None of these solutions will be easy. Pick your poison.
Old 06-09-2011, 07:04 PM   #9
Rewards Points: 14
Thank you for the input!
Old 06-09-2011, 07:48 PM   #10
Rewards Points: 1,520
Why not just end the baseboard there with a return? Paint the base by the cabinet and only you will notice.
bob22 is offline   Reply With Quote
Old 06-09-2011, 09:37 PM   #11
DIY staff
Rewards Points: 7,174
Lone---That detail really caught my eye ! Nice fix.---Mike---
loneframer (06-09-2011)
Old 06-09-2011, 09:45 PM   #12
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
True that, double true!
WirelessG is offline   Reply With Quote
The Following User Says Thank You to WirelessG For This Useful Post:
Old 06-09-2011, 10:09 PM   #13
KemoSabe
loneframer's Avatar
Thanks Mike.
Here's another one that I conjured up when the HOs decided to wainscot the curved stair. I needed to end the chair rail into the apron under the landing nose.
Old 06-09-2011, 10:33 PM   #14
DIY staff
I just drooled all over the key board when you ran that thread next door at CT.
I love trimming--it's not often that I get to do nice complicated trim like that.
Art with wood!
Your kids must have enjoyed seeing your work. Nice customers to invite you into their open house.---Mike---
Old 06-09-2011, 11:30 PM   #15
Rewards Points: 256
im just curious why you " the op" didnt use bullnose trim pieces at the corners?
oldrivers is offline   Reply With Quote
What color to paint kitchen cabinets? kimberland30 Interior Decorating 20 11-28-2015 04:33 PM
Woodgate Stock Kitchen Cabinets (got photos?) sbazzle Kitchen & Bath Remodeling 20 02-09-2012 03:52 PM
Kitchen cabinets gmhammes General DIY Discussions 10 11-03-2011 12:43 PM
Newbie Redoing Kitchen Floor jcostas Flooring 2 05-21-2010 01:24 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-30-2008 12:46 AM
