T101BR Up Stroke Blade Clean Cut! - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 07:37 PM   #1
T101BR up stroke blade clean cut!
I am experimenting with cutting into the sink hole on a laminate countertop I got some metal blades but they are too short. SO I used a T101BR Bosch up stroke blade and you can see it's very clean cut in case anyone is searching this topic
petros151 is offline   Reply With Quote
Old 07-23-2012, 08:26 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
I saw this on, what else?, a DIY show. It cuts on the downstroke. Nice!
JulieMor is offline   Reply With Quote
Old 07-23-2012, 09:50 AM   #3
Rewards Points: 502
If I'm not mistaken, Bosch jigsaws cut on the downstroke, which gives a cleaner cut anyway. Once got a Makita saw which cut on the upstroke - nightmare.
tony.g is offline   Reply With Quote
Old 07-23-2012, 10:14 AM   #4
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
The down cut T101BR is a must for cabinet installation. Items like fillers and toe kick facings can be cut accurately without sanding.
The downside to this blade is "chatter" as it tends to bounce the saw around..........especially if you hit a staple in the counter top. We have had a jigsaw bounce right out of the kerf and hop across the plastic laminate ruining the surface.
What I did was to glue a piece of smooth rubber to the jigsaw plate. This helped the chatter and also protected the finish from scratching. The saw takes a little more down pressure on whatever we were cutting.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Bosch Multi-X Blade DONE in 2 minutes miamicuse General DIY Discussions 8 06-25-2012 12:49 AM
How to clean porcelan tiles? Talking Dreams Tiling, ceramics, marble 4 02-08-2009 10:01 AM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
Creating a clean, sharp caulk line? JDuc Painting 5 01-18-2008 09:14 AM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
