T&G Subfloor Expansion Gaps? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-09-2014, 10:51 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Hey gang-
I am in the midst of a whole-house remodel (100+ years old) and am currently working in the kitchen/informal dining area.
Upon removing the original T&G hardwood finish flooring, I found that the subfloor consists of 3/4" thick, 6" wide non-T&G pine planks. This subfloor is in really bad shape and I would like to remove all and install a 3/4" T&G plywood subfloor, glued and screwed.
The following may seem like a strange question, but what is the typical practice of leaving expansion gaps between sheets of T&G plywood? I've done a fair amount of investigation and some installers butt all interior joints snug whereas others recommend leaving a small gap (thickness of a quarter or nickel) at each joint. It seems that an expansion gap is always recommended between seams of non-T&G plywood.
I live just outside of Chicago, Illinois.
Any advice would be appreciated as I am growing confused over all of the differing installation strategies that I'm finding.
Thanks!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 08-10-2014, 12:39 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by BigJimmy View Post
Hey gang-
Thanks!
Jimmy
I think most of todays T&G subflooring is self-spacing.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
joecaption (08-10-2014)
Old 08-10-2014, 08:25 AM   #3
Rewards Points: 14,312
The tongues are longer then the groove is deep to make it self gapping.
Do you a favor and use real Advantech subflooring. Stronger, no voids, far more moisture resistant.
Unless you have a stand up screw gun I'd stick with 8D ring shanked nails and use a framing nail gun.
Old 08-10-2014, 04:29 PM   #4
Rewards Points: 548
Tack in a couple of 8 or 10 penny nails on the butt ends, advantech is self-gapping on the long seam. GLUE and screw. Just did the deck of a two story garage, very easy stuff to use (tap into place with a five lb. sledge and a block). We ended up just using screws every siix inches on the whole thing. Had plenty time and a battery powered makita drill/driver, no worries. Ron
ront02769 is offline   Reply With Quote
expanding foam for gaps in masonry foundation LMHmedchem Concrete, Stone & Masonry 6 08-22-2012 09:36 PM
Line spacer gaps in concrete driveway and sidewalks - ok to fill up gap? daluu Concrete, Stone & Masonry 3 07-25-2012 10:20 PM
Basement Window / Buck Gaps and Leaks ? Carles Windows and Doors 2 07-01-2012 12:06 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 11:01 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
