T&G Pine Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 08:50 AM   #1
T&G pine ceiling
I am going to do a tongue and groove pine ceiling at my cottage. I planned on strapping the roof trusses (24 o.c.) with 1x4 strapping at 16 o. c. then tongue nailing the pin to the strapping. The pine would run vertically.
Has any one done it this way or does any one see a problem with this method.
thanks gulbworks
gulbworks is offline   Reply With Quote
Old 05-29-2011, 09:21 AM   #2
Civil Engineer
Rewards Points: 4,520
Couple of questions. If this is a ceiling, how do you plan to put the pine in vertically? I assume you mean horizontally, but maybe I am totally confused about your plan.
As to nailing T&G to 1x4 strapping, that is pretty sketchy. Most of the T&G ceilings I have seen were attached directly to the floor joists, 16 inches OC. Since you have roof trusses, you would need to check with the truss manufacturer if it is acceptable to nail to the bottom of the trusses, if you plan to do it that way.
Daniel Holzman is online now   Reply With Quote
Old 05-29-2011, 12:25 PM   #3
recently retired
Rewards Points: 280
T&G is generally run horizontally, since it is a ceiling 24 oc is not a problem. However you should have drywall up first for fire considerations. Nailing into the trusses in fine.
Keith Mathewson is offline   Reply With Quote
Old 05-29-2011, 01:05 PM   #4
Too Short? Cut it Again!
Agreed you need some sort of fire barrier. And personally I thing nailing the pine vertically is going to look kind of weird. And vertically, I am not sure what you would nail it too without putting something the equivalent of a subfloor for a ceiling up there which will put a lot of weight on the trusses.
You know they do sell nice looking veneer sort of paneling for these sort of applications. Nice versions are pricey but you could hang it with the pattern vertical if going for a look.
Old 05-29-2011, 10:52 PM   #5
Daniel, sorry I left out an important detail, the ceiling is a cathedral ceiling. The T&G would be parallel to the roof trusses.
That's beautiful woodwork Keith.
In this area I don't see drywall being installed first before the pine. It sure sounds like a good idea for fire. Thanks for bringing this up. I'll ask my building inspector if he requires it.
Old 05-30-2011, 07:46 AM   #6
Rewards Points: 1,528
"I'll ask my building inspector if he requires it."
It would seem that a good idea is a good idea whether or not if the inspector requires it, no?
bob22 is online now   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Vaulted Pine T&G Ceiling Jambo Diego Building & Construction 1 05-08-2009 06:59 AM
