T&G Cedar For Closets... Use Outside? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 06:50 PM   #1
Rewards Points: 150
T&G cedar for closets... use outside?
'ya know those kits that are like 1/4" cedar T&G boards you tack up in a closet,
I was thinking of making some planter boxes out of 2x4s and putting those on the outside... a poor man's cedar planter
Any problems with this? Would they hold up alright outside?
johnnyboy is offline   Reply With Quote
Old 03-10-2010, 06:50 AM   #2
The material used for lining closets is aromatic cedar, not sure how that would hold up outaside. Planter boxes are usually lines with copper, tar, or similar to waterproof the inside.
Old 03-10-2010, 10:09 AM   #3
remodeling pro
Most of the cedar used for exterior work is western red cedar, and as stated the material you have is aromatic cedar. I don't believe it is very weather resistant.
troubleseeker is offline   Reply With Quote
Old 03-10-2010, 10:23 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
actually it is highly stable with regards to moisture and has alot of the kinds of oils in it that helps repel insects,it's also called eastern red cedar or juniper cedar
with the proper details with regards to pans and drainage it should hold up fine
Tom Struble is offline   Reply With Quote
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
cedar deck looks like crap silky Painting 16 05-02-2009 11:42 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
Cedar T&G Ceiling boiga Painting 8 10-12-2005 06:30 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
