Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-27-2009, 10:42 PM   #1
Default t&g
finishing up a new house and im going to install a tounge and groove ceiling. i debating weather to sheat the ceiling first with 7/16 osb or nail it directly to the rafters. the raftes are 24" ocand its cathedral ceiling. any opinions are greatly appreciated, thanks !!!!
roadhouse is offline   Reply With Quote
Old 10-27-2009, 11:09 PM   #2
You'll be okay nailing it directly to the ceiling. The osb would not serve any purpose. If the rafter's don't plane out well you may have to shim a little.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 10-27-2009, 11:17 PM   #3
i was kinda hopig for this answer, but i just want to do right the first time and not wonder if i shouda did it another way. iv also heard people say not to wory about landing butt joints on a rafter becaus the boards above it and below it will hold the jont , any opinions ?
Old 10-28-2009, 08:24 AM   #4
Always land butt joints on solid framing. It helps keeps the joint tight.
Old 10-28-2009, 09:42 PM   #5
Remodeling Contractor
Unless the ends are t+g also, then no need.
eisert is offline   Reply With Quote
Old 10-28-2009, 10:28 PM   #6
I'd be concerned my conditioned air leaked through every crack on every board without an air barrier. Contributing to water in the batt glass insulation going to to ridge vent, depositing on the framing and /or kraft paper facing causing mold and rot. Possibly causing the joints to swell and shrink with the heating/cooling. Unless you had spray foam hot roof, even then....
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 10-28-2009, 10:49 PM   #7
gbr, so your saying that even with faced insulation id still need a secondary vapor barrier, ie; the osb. i dont have a problem sheeting it i just want to make sure its neccesary. please fill me with info, anybody!
Old 10-28-2009, 10:51 PM   #8
what about using polly under the t&g
Old 10-28-2009, 11:21 PM   #9
also the cathedral ceiligs are scissor trusses with faced r38, vented soffit anad a ridge vent the entire length of the roof.
Old 10-29-2009, 12:45 AM   #10
ArmchairDIY's Avatar
No need for osb sheathing, but a vapor barrier is needed. Kraft Faced insulation does tend to get caught in the grooves, but it can be done. I prefer poly (visqueen) for ease of installation.
Narrow boards or end matched boards are fine to install without landing on the joists or rafters.
ArmchairDIY is offline   Reply With Quote
Old 10-29-2009, 03:28 PM   #11
Very cold climate, poly sheeting, all others except gulf, house wraps next to warm side: http://www.buildingscience.com/docum...on?full_view=1
Be safe, Gary
Old 10-29-2009, 06:22 PM   #12
What is the thickness of the material you're putting up? I wouldn't put up thin material on a 24" span.
Ron
Old 10-29-2009, 11:24 PM   #13
the thickness of the material.3/4". i think it should be thick enough for a 24" span.
Old 10-30-2009, 11:06 AM   #14
Just make sure the vapor barrier is in place and the moisture content of the wood is appropriate.
I would seal the backs of this wood to eliminate moisture absorption.
Ron
Old 10-31-2009, 09:08 PM   #15
Default T&G Ceiling
I'm installing T&G pine panelling on basement ceiling...do I install the first panel with the T or G out? Do I nail in the T or G?
SReid is offline   Reply With Quote
More On This Topic
One of the biggest challenges in maintaining a greenhouse is humidity control. Most plants enjoy a humidity of 50 to 60 percent, and this is a challenge to manage at times. The main goal is to avoid condensation on plants, which promotes mold and fungus... Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Installing a Door Threshold
Installing a Door Threshold by Expert Village
We’re installing a back door threshold. Now in this one, we’re going to have to install an oak board. You want to make sure that that is oak so that it won’t rot away. And this slab slopes inward, which has caused a lot of problems with... Read More »
In this clip I'm going to talk about removing our pot from the batt. I have undercut our piece of pottery with our wire tool, I've run water under it which helps it to hydroplane, sort of how a tire would hydroplane on a wet road surface, creating it... Read More »
How to Caulk Interior Walls
How to Caulk Interior Walls by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Now we're going to start caulking. Now, when we're caulking for the exterior, interior painting, the main things we want to look at are door jamb... Read More »
Pine T&G Flooring AJ&J Flooring 1 04-16-2009 10:09 PM
1x6 16' T&G Ceiling (Hang and Stain) themayor Building & Construction 5 03-07-2009 11:59 PM
Refinishing square cut side of 2x6 T&G for flooring cowbore Flooring 1 11-24-2008 03:13 PM
Do I need plywood over t&g sheathing on this house?? 4just1don Building & Construction 5 11-17-2008 01:20 PM
Used T&G OSB as sheathing on a 22' wall, problems ? iMisspell Building & Construction 3 10-16-2008 12:49 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
