Swinging Garage Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 08:59 AM   #1
Hey everyone, I am looking to install a set of swinging doors on a garage. My question is has anyone ever sucessfully used t1 11 in this situation, the doors will be big, basically each one will be a full sheet of plywood hanging by hinges on end. I want to make sure that there is no type of twisting, buckling issues. Any other ideas for material. Cannot be expensive such as exotic woods etc..
Justin08 is offline   Reply With Quote
Old 11-16-2008, 10:59 AM   #2
how-to-do guy
Send a message via Skype™ to how-to-do-guy
T-111 can be used but it sounds like you are trying to do it the cheapest way possible. The best way to do it is to use some framing material around the edges and fasten securly. Also, use heavy duty gate type hinges so that you can use through bolts. To avoid buckling in the center fasten with framing material. To avoid twisting, latch both doors top and bottom. It also helps if you can apply an astrigal with which the doors will overlap.
how-to-do-guy is offline   Reply With Quote
Making carriage style garage doors Jill General DIY Discussions 16 10-31-2012 06:06 PM
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-19-2011 11:58 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
Garage Doors, Torsion Springs Burat Building & Construction 11 05-10-2007 12:25 PM
