A Survey For DIY Woodworkers - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 08:42 AM   #1
A survey for DIY Woodworkers
Hello, my name is Jeff Alger.
I'm taking a Master's class in Instructional Design at Boise State University. My group's project is to develop training that teaches people how to strip the wood trim inside their house and ready it for refinishing (I'm not kidding, that's our actual project!). The first step we have to do is find out why people don't refinish their own interior trim. So, we developed a survey to find out. Can I ask the DIYers on this board to take a couple minutes and answer the following questions? Any help you can give would be greatly appreciated.
Thanks!
Jeff
Do you know how to prepare wood trim for refinishing?
If so, where did you learn how to do it?
Have you ever refinished wood trim or furniture before?
If you wanted to refinish the trim in your house, would you consider doing it yourself?
If not, what would you say the biggest barrier to doing it yourself was?
MangoMan is offline   Reply With Quote
Old 02-12-2011, 12:10 PM   #2
DIY staff
Rewards Points: 7,174
Refinishing trim in place usually ruins the paint on the walls--adding a new paint job to the work.
Most trims cost $1.00 to $2.00 per foot to replace--(plus labor to install) Stripping would cost that much or more---Just cheaper and faster to replace the trims.
If the trims are irreplaceable antiques--Then stripping is justified---a jell stripper and mesh is the preferred method used by pro strippers--Very pricey.---Mike---
Old 02-12-2011, 02:15 PM   #3
Rewards Points: 5,336
Thanks!
Jeff
Stripping trim is a limited use project as Mike mentioned. The only time I'd bother would be because it was architectually worth while. Stripping a 1938, oak trimmed house would be a worth while project. Very, very costly to hire out, but worth while if you're doing it yourself.
Ron
Old 02-12-2011, 03:46 PM   #4
Does your training include the lead abatement info?
mrgins is offline   Reply With Quote
Kneepad Survey - finding solutions to common problems Rudy M General DIY Discussions 0 02-02-2011 01:05 PM
Survey on Trex composite decking TC1 Carpentry 22 04-13-2010 01:21 PM
Timber-Tech Survey darylbrands Building & Construction 1 04-08-2008 06:23 PM
Survey Results - Cavity Wall Insulation - Health Concerns mchu6am4 Building & Construction 5 03-14-2007 02:50 PM
