Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-09-2009, 11:15 AM   #1
Default Support for opening
I am ripping out a wall in my house and i need to now how much support I need. The opening is going to be 16ft. long I was going to use 3 2x6x16,but I did not know if that was going to work or if I should use 2x8 or 2x10. Any suggests?
Marc Christie is offline   Reply With Quote
Old 07-09-2009, 11:19 AM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
Interior wall?
Load bearing?
2x6's will not work, especially if its load bearing
I took out a 12' load bearing wall & needed (2) 14" LVL's
But that was supporting a wall above & roof load
My lumber company sized the wood for me for free
Old 07-09-2009, 11:27 AM   #3
Default What are LVL's
What are LVL's? What size of boards would you use for this?
Old 07-09-2009, 11:51 AM   #4
Originally Posted by Scuba_Dave View Post
Interior wall?
Load bearing?
What size should I use? 3 2x10x16's?
Old 07-09-2009, 02:38 PM   #5
Custom Cabinet Maker
Marc: I think it would be best if you consult either your building inspector or a structural engineer.
skymaster is offline   Reply With Quote
Old 07-09-2009, 07:26 PM   #6
Scuba_Dave's Avatar
I did not size my beams, you can't guess at this
You have to go to a lumber company/engineer & have them determine the load & size your beams
My beams were sized & then plans were sent out for an engineer review & stamp = required for my permit
Old 07-09-2009, 08:43 PM   #7
the last 16' foot span we did needed an I beam.
Get an engineer. Thats a long span.
II Weeks is offline   Reply With Quote
More On This Topic
How to Clean a Bathtub
How to Clean a Bathtub by Expert Village
This is Kevin with Expert Village we are going to one day bathroom remodel. The final part of the bathtub cleaning preparation once we remove the sealer strips that we already got down here would require rubbing alcohol to get the really fine layer of... Read More »
How to Strip a Bathtub
How to Strip a Bathtub by Expert Village
This is Kevin with Expert Village we are going to one day bathroom remodel. (taking caulk off) Here is the knife I would show you how fast it is just go all the way under and then from above go like this. It goes on top but as it goes there we go. Now I... Read More »
This is Kevin with Expert Village we are going to one day bathroom remodel. We are going to brighten up this bathroom a little bit and make it look presentable. As you have already seen it's not in the greatest shape but there is a few things that we can... Read More »
This is Kevin with Expert Village we are going to one day bathroom remodel. Around the faucet and fixtures we are going to come over here and put some caulk you see we had some old clear caulking and it is showing a lot of dirt and grim and it was not... Read More »
This is Kevin with Expert Village we are going to one day bathroom remodel. Drying off and just starting applying. Once you are completely clean and dry make sure there at it is absolutely dry and you can pull the sealer out. If you don't have someone... Read More »
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 07:07 PM
Adding support to "springy" floors-this mom's got to do it herself! LOStouten Building & Construction 10 11-12-2008 10:38 PM
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 09:32 PM
Replacing support beams Annimal76 Remodeling 1 09-10-2007 12:12 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 10:55 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
