Support For Countertop - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 11:25 AM   #1
Rewards Points: 874
Support for countertop
We removed (2) columns(not load bearing) that helped support this kitchen counter. There is still one column but the counter is not not sturdy. It moves a lot where those vertical 2x4's are attached to the bottom 2x4 on the floor. We are getting a new counter top but is there a system/design to support a counter like this underneath? Do the 2x4's need to be crossed? Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 03-24-2013, 11:34 AM   #2
Rewards Points: 13,270
You can not balance a counter top on a single row of 2 X 4's like that.
Also there's not even a bottom plate, all that needs to go.
Not going to have cabinets under it?
If not your going to have to build two new knee walls to support the top.
Old 03-24-2013, 11:59 AM   #3
Rewards Points: 874
As always,,thanks. Isn't the bottom(horizontal 2x4) a bottom plate? if not, what is a bottom plate? Thanks.
Old 03-24-2013, 12:28 PM   #4
Rewards Points: 220
perhaps a angled 2x4 will steady it. but from the pics, its hard to tell what is there = too much stuff on the counter and pics taken too close.
Fix'n it is offline   Reply With Quote
Old 03-24-2013, 12:37 PM   #5
The bottom plate may just be buryed under all the layers of flooring.
Even if there is a plate a single skinny wall like that's not going to work.
Mstrlucky74 (03-24-2013)
Old 03-24-2013, 12:50 PM   #6
Roofmaster
Rewards Points: 2,172
You need to build another knee wall on the floor about a foot from this one and install X bracing or a couple of corner braces (The bigger the better) between plates and studs. Attach corner brackets with no 14 x 1.5 inch HWH screws.
The Following User Says Thank You to jagans For This Useful Post:
Old 03-24-2013, 07:06 PM   #7
Rewards Points: 874
The baseboard poses a problem. If I build another knee wall then I have to move the baseboard further out which kind of interferes with the space. Thanks.
Old 03-24-2013, 07:49 PM   #8
Rewards Points: 220
i think i could make it work. but those pics are still not good enough (too close)to see just what is going on there.
Old 03-24-2013, 08:11 PM   #9
Rewards Points: 874
Hope these help....trying.
Old 03-24-2013, 08:49 PM   #10
Rewards Points: 220
would it be ok to make that 1/2 wall thicker ? say, 3" more.
is it centered under the counter top ?
Old 03-24-2013, 09:22 PM   #11
Lord of Slums
Rewards Points: 1,974
staggered blocking between the studs and sheet it with 1/4 plywood. Any questions refer to post # 2. Especially the part about the single wall
mj12 is offline   Reply With Quote
Old 03-24-2013, 09:39 PM   #12
Rewards Points: 874
So are you saying the staggered blocking is for the SINGLE WALL? Thanks.
Old 03-24-2013, 09:57 PM   #13
Roofmaster
Not to make you feel bad, but there is not much there worth saving. You may want to re-think your approach.
mj12 (03-25-2013)
Old 03-25-2013, 09:03 AM   #14
Rewards Points: 874
I understand and agree. thanks. Just want to try and build one wall with supports and not have to move the baseboards.
Old 03-26-2013, 06:03 AM   #15
Rewards Points: 874
Sorry Fix. I think we could.....why? Its not centered. I assume centering it would provide better stability.?
Old Weather Head support connection problem RMCNABB Electrical 2 06-17-2011 05:27 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 04:07 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
