Support Below Non-bearing Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 05:06 PM   #1
Rewards Points: 59
Support below non-bearing wall
I am moving a non-bearing wall in my bathroom remodel. The new wall will be parallel to the floor joists, with the edge of the wall about 1" from the centerline of the joist. Do I need to put any blocking below this wall? I would rather not rip up the subfloor if I don't need to.
The existing non-bearing walls (house built in 1991) just sit on the plywood.
Thanks!
handyman923 is offline   Reply With Quote
Old 02-24-2011, 05:16 PM   #2
Rewards Points: 5,336
Thanks!
Attaching it to the subfloor will be fine. You'll need blocking on top though.
Ron
Old 02-25-2011, 09:09 AM   #3
Agree with Ron. For the ceiling blocking, you can rip some plywood that will span the gap left in the ceiling as well as overlap the wall plate and the drywall. I usually pop in a temporary screw on the face so I can pull down on the plywood blocking while pushing up to screw the block in place
mrgins is offline   Reply With Quote
Load Bearing Wall / Additional Support Needed??? bainer1290 Building & Construction 15 12-22-2010 04:44 PM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
Bearing Wall ? mroc Building & Construction 9 10-15-2010 06:21 PM
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 09:37 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
