Support Beam - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 06:32 PM   #1
support beam
What are the safest cross dimsnsions of a horizontal support beam that will hold up a 13 foot span along the first floor ceiling of a 2-story home with attic ? (no other columns). My friend wants to use 3 two by sixes of a medium grade wood and I believe it should be 1 four by eight, preferably of oak or red oak.
kevingerard is offline   Reply With Quote
Old 03-20-2011, 06:55 PM   #2
kwikfishron's Avatar
Rewards Points: 422
What’s holding it up now?
kwikfishron is online now   Reply With Quote
Old 03-20-2011, 07:11 PM   #3
support beam
8 two by four posts across the middle of that half of the house, which we want to remove and substitute with one lateral support beam(s). Also, the 2nd floor "floor" beams run perpendicular to this, and only go half way, meeting in the middle of the house on top of the current cross beam (which of course doesn't hold weight but transfers the load to the posts). Our support beam will then have to hold most of the weight of the middle area of that half of the house, above the 1st floor.
Old 03-20-2011, 07:31 PM   #4
Rewards Points: 422
Nobody here or anywhere on the internet can answer that for you.
You need to have a Structural Engineer do a on site inspection.
Main structural support beam HELP!!! Daniel048225 Building & Construction 34 02-16-2011 11:35 PM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-28-2011 11:10 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
