Support Beam - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 10:23 AM   #1
support beam
I have a lake cottage that has an attached porch approximately 8x8. The only support are 3 4x4 posts underneath.
My question is what size beam should be used to properly support this.
I want to put a beam (2x6 nailed together across the entire length and then the support posts under that.
Will that be sufficient.
thanks
mcn520 is offline   Reply With Quote
Old 07-12-2011, 10:35 AM   #2
AGWhitehouse's Avatar
Hard to know what you're dealing with based on that description. Pictures? Sketch of plan?
AGWhitehouse is offline   Reply With Quote
Main structural support beam HELP!!! Daniel048225 Building & Construction 34 02-17-2011 12:35 AM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
