Support For 5ft Bookcase Shelves - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 08:51 AM   #1
Rewards Points: 77
Support for 5ft bookcase shelves
Any suggestions on how to keep a 5ft long 3/4 oak plywood shelf from sagging over time? They will be about 16" deep. I plan on using a 3/4" router groove on sides. Also screwing into shelves thru a 1/2" plywood back.
I thought about using a solid wood face that would over hang shelf face underneath & then attaching a piece of angle steel or alum. to the face & under shelves. The face would hide the steel. I would rather not use a pillar or center support if I can avoid it. The shelves would have to support some stereo components & cd's etc. Nothing heavier than that. No books.
Thanks for any suggestions.
dbldee20 is offline   Reply With Quote
Old 01-05-2009, 08:59 AM   #2
I think you'll have to use the angle iron if you don't want a divider.
You can enter the dimensions and materials at the web site below to see, but a fixed shelf that wide, even with a 1x2 red oak facing, will likely sag too much.
http://www.woodbin.com/calcs/sagulator.htm
justin2009 is offline   Reply With Quote
Old 01-06-2009, 04:24 AM   #3
Maybe double the shelves up to 1 1/2". Remodeled a house with around 4' wide bookshelves that were doubled up and they were still really straight. But again the largest was only about 4 foot. I guess it also depends on what you might be putting on them.
sausagefingers is offline   Reply With Quote
Old 01-06-2009, 06:21 AM   #4
Maybe something like this?
http://www.hangmanstore.com/Hangman-...s-p/sst-48.htm
http://www.hangmanstore.com/Hangman-...p/hdsst-48.htm
If not, I would just put the hardwood face on the shelf with biscuits or pocket screws.
jerryh3 is offline   Reply With Quote
Old 01-06-2009, 06:32 AM   #5
47_47's Avatar
Rewards Points: 62
You could use solid 1-1/8" stair tread material for the shelves. This should be fine for electrical components.
47_47 is offline   Reply With Quote
Old 01-07-2009, 08:06 AM   #6
Rewards Points: 77
Thanks for the info. I have decided to add some pullouts for cd storage, which will require a center wall.
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 05:07 PM
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 07:32 PM
Extending pantry shelves info@homeworkbydave.com Carpentry 6 10-24-2008 08:57 PM
bookcase wall Jim Mac Carpentry 2 07-11-2008 04:58 PM
"Floating" shelves Freelancer Carpentry 7 03-05-2006 08:42 AM
