Suggestions On Finishing On Trim For Stairs - Photos - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 08:25 PM   #1
Rewards Points: 153
Suggestions on finishing on trim for stairs - photos
I am in the process of painting the inside of the house.
The last owner never really finished the trim on the stairs.
I am looking for some suggestions on how to make this look good.
theedudenator is online now   Reply With Quote
Old 12-18-2010, 10:14 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
Your skirt board is a little low but I use to install 1 1/8 inch base cap on top of the skirt board and under the landing tread (noising). On the outside of the stairs I would install stair brackets to cover the gap. Even then it isn't going to look professional as there are still somethings not right.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-19-2010, 09:52 AM   #3
Rewards Points: 153
I think the trim on the ends of the stair tread is longer then the tread.
Any suggestions on the caps? Is this something I make? Or buy?
Old 12-19-2010, 10:35 AM   #4
recently retired
Rewards Points: 280
What level of quality are you looking for? If you want to pretty it up a little then do as jiju1943 suggested, but I have to say what you are starting with is a real hatchet job. To warrant the effort of working on it you will most likely want to replace the treads since those are too short and there isn't much room to add brackets.
Keith Mathewson is offline   Reply With Quote
Old 12-19-2010, 07:51 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
on the top of the stringer I would add an 1-1/8" base cap moulding or you could just use a cove moulding like they put on the top off the treads (which tells me they did a bad job and covered it with the cove. There Also should be an open stringer for the risers to miter into but instead they were cut square and left a little long it seems. The only thing I can think of doing that may look ok is to add some tread brackets http://www.kinzelwoodproducts.com/kinzel/default.asp
Millertyme is offline   Reply With Quote
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
wall bowed while finishing up trim kboychuk Carpentry 5 11-30-2010 08:37 AM
Exterior Caulking Suggestions for painted trim to vinyl windows? Learn2Build General DIY Discussions 1 06-04-2010 01:44 PM
Wooden window trim that I stripped looks bad. Suggestions? jpearson311 Painting 15 04-28-2010 10:15 AM
exterior trim paint suggestions AGirlsGottaDoIt Painting 2 03-30-2009 12:06 AM
