Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-03-2008, 03:50 PM   #1
suggestions on contructing a range hood
I'm looking to build a custom hood over a range and I'm looking for some suggestions. I will be installing a complete liner / insert /fan/filter unit that is vented and sized correctly for the range....that's the easy part. The harder part is the custom hood to be built around the mechanical parts.
I don't have a picture, so I will try to explain: the base of the hood will be approx 21" deep x 36" wide. The three sides of the hood will angle up and in towards the ceiling. The rectangular footprint on the ceiling where the sides terminate is approx 14" deep x 18" wide (give or take to allow clearance for insert mechanism and duct). I also need the three sides to be curved (concave). Faux stone edging is going around the edge of the bottom rim so the sides will terminate into the fuax stone edging on the bottom and ceiling on the top side. The side will be sheet-rocked and finished or covered with a sheet of copper.
My question is really around curved sides....how is this (supposed to be) done?
My thoughts: Frame the top and bottom rectangles. Using 2x? lumber (where the "?" is depented on how concave the sides are), cut the curve profile in the 2x lumber and position two pieces per side between the top and bottom of the hood. Cut the curve to allow for finished surfaces to mate up correctly to the faux stone around the lower perimeter.
Install a piece of ply on the front with sides sticking out farther than required. use a piece of cardboard and the "trial and error, trim here / trim there" approach to determine the shape required for the sides. Use the cardboard pattern to cut a piece of plywood. Attach the side curving them in and attaching it to the two 2x ribs. Once the sides are attached, use the sides to guide a blade to trim the edges of the front piece.
The curved ribs supporting the sides would not be in the corners which would leave the curved line where the sides meet unsupported. Figuring the angles required to cut a corner support makes my head hurt. I was going to tie the plywood sides together with a couple of angle brackets (counter sunk). Once I have the plywood base complete with the corners supported, applying the finish will be pretty straight forward.
Can anybody tell me how this is really supposed to be done?
steve1234 is offline   Reply With Quote
Old 10-03-2008, 09:28 PM   #2
DIY'er
jamiedolan's Avatar
I have some ideas, but I am not positive I understand the design properly. So I drew a model for you with your dimensions. I think this is the base to what your describing, but I am not quite sure what the curved areas are suppose to look like, does that extend out past the dimensions that you gave or are the corners more narrow?
-Jamie
jamiedolan is offline   Reply With Quote
Old 10-04-2008, 12:31 AM   #3
Jamie-
Thanks for the sketch. Close but not quite. take a look at the attached. It's not to scale but I think it explains what I'm doing. The dims I provided were estimates.
Old 10-04-2008, 01:34 AM   #4
DIY'er
jamiedolan's Avatar
Jamie-
If I were you, I would draw out the entire thing with exact dimensions in sketchup.
I would start with building the base out of 2x4's and building a frame out of 2x4's as well that run up to the top of the hood, then in the front, I would run 1x1's out to the edge where the of the sloped area is, then I would attach a 1/2x1" furring strip horizontally to the 1x1's. Repeat every 6 inches. Then attach 1/4" flex drywall by screwing it to the horizontal 1x1 strips.
Drawing this up to the exact dimensions in sketch will allow you to see what the exact cut needs to be on the drywall, that is going to be the hardest part.
Did I lose you with that?
Jamie
Old 10-04-2008, 08:04 AM   #5
Drywall contractor
OR instead of 2x? material, use plywood ripped to the proper width and cut your curve profile. Laminate two pieces of 3/4" together to get your 2x dimension. Agree with the 1/4" drywall.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-04-2008, 11:06 AM   #6
Thanks for the input. It sounds like you don't think a plywood surface is required first before applying the 1/4" rock? I like the horizontal furring strips...that should provide a better base so I get a more smooth profile when the drywall is installed. I seems like I could tie the furring strips together where the curved surfaces meet. That's one area of concern in that I want the structure tied together.
Laminated ply to replace the 2x?....nice. The ply should be a bit easier to cut a smooth profile on.
Old 10-04-2008, 12:00 PM   #7
DIY'er
jamiedolan's Avatar
You don't have to have a continuous area that you screw the drywall to, it can span some area, you just need points to attach it to frequently enough that it holds it in place for your curved area. So either vertical cuts of plywood or horizontal strips, either one can be spaced out at least around 6 inches.
Jamie
Old 10-04-2008, 02:48 PM   #8
Drywall contractor
The 1/4" rock should bend to your radius pretty easily. You'll want to use two layers, by the way. You can wet it a bit to help it bow. Lean it against a wall for a couple of days before you're going to use it and it will tend take on a natural bow. (Especially if you have an unfinished basement space that is a bit on the humid side.)
Old 10-13-2008, 06:58 PM   #9
thanks for all the input. Attached are a couple of bad pics taken with a phone. There was a slight change in plans since the original post. The hood will now have a plywood skin applied on the frame overwhich a copper sheet will be applied. Any recommendations on the guage of copper to use? I'm looking for something thin enough (aka cheaper) to easily conform to the curve, but not too thin to dent/crinkle like foil.
suggestions on contructing a range hood-hood-1.jpg   suggestions on contructing a range hood-hood-2.jpg
Old 10-20-2008, 02:20 PM   #10
Got the power pack in, vented, wired, frame complete, and plywood "skin" on. Now on to the copper....
suggestions on contructing a range hood-complet-frame.jpg   suggestions on contructing a range hood-hood-ready-copper.jpg
Old 10-20-2008, 03:36 PM   #11
nice job steve was wondering how this was going to turn out.I have a couple of big convection ovens I need to make a hood for and if I use that design just cut the top portion down I think it will work just fine by the way what size on the plywood I would think 1/2 inch or less to get the bend in it? One more thing did you or are you going to cover the inside with anything to keep the heat from the wood?
clasact is offline   Reply With Quote
Old 10-20-2008, 05:25 PM   #12
thanks. Plywood for the frame is all 3/4". The "skin" is 1/4" (nom)....thin enough to make the curve, but stiff enough to not "flatten" out where the screws attach it to the frame. As for the inside, the insert is all stainless, see the pic.
I still need to put something along the bottom horizontal edge of the frame to cover the stainless flange / wood transition. Two decorative korbels (sp?) will also be added to the wall / hood.
Old 10-20-2008, 05:30 PM   #13
sorry for all the questions but that really looks good and what I need also and I dont like the price of a custom hood so if you dont mind my asking where did the insert come from and how many cfm is it.The way it is made all you would have to do is wrap your copper around the edge maybe even tuck it behind the insert
Old 10-20-2008, 07:11 PM   #14
We chose a Kobe insert. There are a few other manufactures that make a similar insert, but Kobe appears to fit our needs and the price was more reasonable (relatively). I believe it's "Vent-a-Hood" that is the popular brand. Our intended range requires 600cfm min. The Kobe claims 700CFM. The others we looked at were 1200cfm, but more costly.
http://www.koberangehoods.com/product/IN-026.html
We were (still are) working with a tight budget on our remodel, but another way to go is with a similar insert but use an external blower unit. This is suppose to be much quiter as the noise source (fans) are not mounted in the insert rather further upstream near the exhaust side of the ducting system.
Old 10-20-2008, 07:20 PM   #15
sorry, forgot this part...
by reasonable...the insert was just over $700. I also installed the optional liner which is just a bigger stanless frame for the insert. I think that is normally about $130. My dealer gave me this one because a corner weld failed. Nothing that a little reinforcement corner gusset applied to the non-visible side with a little JB Weld couldn't fix.
Other brands of similar inserts were in the $1200+ range.
range hood vent vinman Roofing 6 05-07-2012 02:23 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
Range Hood venting questions Crashless Remodeling 5 04-13-2008 10:30 PM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 05:43 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
