Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-25-2009, 12:43 PM   #1
a woman with questions
Subfloor for wooden porch??
Hi..I have a question. I am going to have a wooden front porch built on my home..there is an overhang and porch posts, but that is all to protect it from the elements. At the moment, there is a deck style porch there..very basic and horribly built,so I cannot use it as a "blueprint" for replacement. To have a smooth,attractive wooden floor..do I need a subfloor or will that not allow water to drain properly through it? I don't know the standard way these things are done...any advice would be appreciated.~thanks~
mlb145 is offline   Reply With Quote
Old 03-25-2009, 08:19 PM   #2
normally its an open floor joists @16" on center with pressure treated lumber.
II Weeks is offline   Reply With Quote
Old 03-25-2009, 08:25 PM   #3
Xtreme DIY'r
Water needs to drain off in some manner
You can either slope the floor, or leave spaces between the planks to allow water to pass thru
No subfloor should be required. Unless the finish wood is very thin
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
Porch roof tie in question dabensys Carpentry 6 08-11-2008 03:46 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 10:33 PM
