Subfloor On Stair Landing - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 08:12 PM   #1
subfloor on stair landing
just finished putting together the upper landing for doug fir stairs..here are the dimensions: (these are rough estimates)
height of landing is 48"
Length is 60"
Width is 60"
Have a post in the middle for support of flooring..from post to post is roughly 20 inches.
Doug fir posts are 6x8
will be covering the landing with 2x8 pine tongue and groove
Question: Can I just secure the 2x8s directly to the posts? I want the bottom of the 2x8s to be visible under the landing. Or do I need to lay down a 1/2 osb?
let me know
chulett is offline   Reply With Quote
Old 02-20-2011, 06:40 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
I don't understand the post thing but 2X8 will be more than strong enough if you have the frame work with joists correct. If you are trying to span 60 inches with just the 2X8 T&G you will not have the support needed.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-20-2011, 08:45 PM   #3
ok, here a photos of the stair landing:
actual dimensions are:
width: 60"
height: 53 1/2"
depth: 58"
the distance between the middle post is 21 1/2" on west and 23" on east..reason is the placement of the timber frame for house..hope this clears up some confusion..a picture is worth a thousand words!
Yes, I will span the 60 inches, but there is a 5 1/4" beam bout half way..
So with these pics..do I need a subfloor?
Old 02-21-2011, 05:30 AM   #4
In short: no
mrgins is offline   Reply With Quote
Tile landing Carpet stair Transition Tmint Flooring 1 02-04-2011 04:35 AM
MA Stair Landing Requirements??? 20knots Building & Construction 4 01-07-2011 06:04 PM
Adding a Stair Landing? Is it Possible? Evil Scotsman Carpentry 4 11-17-2010 08:19 AM
newel fixing to stair landing joanna21 Carpentry 10 02-16-2009 11:23 AM
4'x7' Landing in the middle of stair, glue or floating? liguowei70 Flooring 1 09-06-2007 05:03 PM
