Subfloor Ok For Framing Inspection? - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 12:29 PM   #31
Rewards Points: 278
Originally Posted by gregzoll View Post
Local metal shop can cut the plate & drill the holes, per Architect engineering plans.
The inspector referred me to the below
http://www.strongtie.com/products/co...s-hst-lsta.asp#
http://www.strongtie.com/products/connectors/RPS.asp#
dgfit is offline   Reply With Quote
Old 02-04-2014, 01:06 PM   #32
Rewards Points: 6,652
That is fine. But sometimes you have to have the straps made specific to the job. That means having drawings made up, and taking them to a local metal shop that deals with these kind of items.
The Following User Says Thank You to gregzoll For This Useful Post:
dgfit (02-04-2014)
Old 02-04-2014, 04:50 PM   #33
Registered User
Rewards Points: 5,514
Glad you have such available code requirements nearby. You can DIY, that is our goal here. Sounds as if you have it all under control or at least know the proper procedure. Be sure to ask the correct nail spacing on the straps, if they didn't tell you already. Filling every hole or every other hole is usually called out on the engineering plan; check the fastener schedule- ask to be certain. At least in my experience framing houses (over 350) since '73 to '03, then strictly remodel till now.
The links are for showing correct procedure/science/info/magnitudes more than I can type in my answer; trumping opinion/way I was taught/way we do it here- answers.
Simpson's are already engineered/warranted, why pay again... IMO.
Gary
PS, like this from my Post 21; http://publicecodes.cyberregs.com/ic...9_6_par021.htm
Old 02-04-2014, 05:20 PM   #34
Gary, in some cases you cannot use the Simpsons, and need something custom for the situation.
Old 03-05-2014, 05:16 PM   #35
Rewards Points: 278
Thought you might want to see some current pics. I wound up installing 10 plate straps total. Subfloor is in and perfectly level in all directions thanks to laser level, shims and plane. Screwed down every 4". Inspectors want to do plumbing rough in and building inspections at the same time so now gonna frame the linen closet and install new DWV and pex (which completes an entire replacement of all supply lines in the house except one other bathroom which comes later)
The Following User Says Thank You to dgfit For This Useful Post:
Gary in WA (03-07-2014)
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
Preparing for Inspection - I pulled the permit diy2morrow Electrical 4 08-17-2011 03:14 PM
Rough-in Inspection Shaotzu Electrical 4 03-31-2011 08:47 PM
Passed my rough inspection, now what? theatretch85 Electrical 12 05-03-2009 02:11 AM
Home Inspectors / Non Disclosed Issues PreSale AndrewF Off Topic 14 02-06-2009 10:18 PM
