Stud Finders - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 05:52 PM   #1
harleyman's Avatar
Stud Finders
I've been looking up different stud finders and have found that a majority of them range from 15 to 50 dollars. Does anyone on here have preferences to which brand/model is better?
Thanks!!
harleyman is offline   Reply With Quote
Old 12-13-2010, 03:00 PM   #2
Handyman
Rewards Points: 512
I saw one at HD a few months back which had multiple sensors. The light would shine different colours for whatever is behind the wall be it wood, copper (metal) or brick. If you are going to use it a lot then I would opt for that one. I usually just measure 16" from the stud side of an electrical outlet or just use the knucle-knock method.
canadaclub is offline   Reply With Quote
Old 01-03-2011, 01:39 PM   #3
harleyman's Avatar
Thanks for the advice canadaclub. I'm actually only using it this one time to hang up a dartboard at the house, but I'm sure that I'll find other uses for it down the road. Take care. Happy New Years!
Old 01-03-2011, 01:44 PM   #4
A Little Of Everything
Rewards Points: 1,356
Get a cheap one. I picked up a cheap Zircon - on sale - from Menards. It works fine for what I need.
The more expensive stud finders typically have advanced features, including electrical wire detectors, with of stud, and thickness of wall detectors. If you don't need those things, don't pay for them.
For hanging a dart-board, go cheap. Depending on the kind of wall, you can probably just tap it with your finger and find where the studs are - or measure from an outlet.
DrHicks is online now   Reply With Quote
Old 01-03-2011, 01:58 PM   #5
I've been an electrician for a long time and have tried out many different products. In the end, I keep going back to using a strong magnet and a finish nail as the best and most accurate stud finder.
General is offline   Reply With Quote
The Following User Says Thank You to General For This Useful Post:
DrHicks (01-03-2011)
Old 01-03-2011, 09:50 PM   #6
carpenter
i use metal studs alot & the best one i got is a cow magnet on a thin string i glue an elc. cap on w/sting, real good to find drywall screws, you can get them at farm & fleet
samps70 is offline   Reply With Quote
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 01:32 PM
Adding new stud (framing for a door), can only access one side ckk Building & Construction 2 06-04-2010 06:50 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
Is it safe to remove this stud? lofar Remodeling 4 06-17-2009 12:22 AM
Any good stud finders? fw2007 Tools 19 05-15-2008 08:37 AM
