Stuck With My Room Door, - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-13-2013, 10:06 AM   #1
Stuck with my room door,
I am really pissed off from my room's door its not closing properly? What could be a possible reason?
eliciasam1 is offline   Reply With Quote
Old 09-13-2013, 10:14 AM   #2
bbo
elephant in the way?
could be many reasons. something wrong with door/frame/door swelling in humidity/hinges/floor/other object/etc.
what happens when you try to close it? what kind of door? any pics available?
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
woodworkbykirk (09-13-2013)
Old 09-14-2013, 11:24 AM   #3
Rewards Points: 79
Spiteful door. You probably closed it too hard.
eclark is offline   Reply With Quote
Old 09-16-2013, 03:18 PM   #4
Rewards Points: 274
I think door swelling in humidity.
alexjoe is offline   Reply With Quote
Old 09-16-2013, 05:04 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
When the doors to my kids rooms don't close, I can usually solve the problem by removing the junk around the door.
Right now my 7 year old daughter does not have a door....she slammed it one time to many so I took it off....she gets it back when she behaves for more than one day....at the rate she is going...the next door she has will be in college...
Old 10-07-2013, 11:47 AM   #6
Well I found the same problem with my door, thanks ddawg16
Old 10-07-2013, 09:05 PM   #7
Rewards Points: 236
Fix'n it is offline   Reply With Quote
Old 10-08-2013, 09:01 AM   #8
Originally Posted by Fix'n it View Post
hehehe
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
Raynor Garage Door Opener - Stuck - Please Help! donfan23 General DIY Discussions 2 10-01-2008 07:34 AM
stuck garage door stuckdoor General DIY Discussions 7 08-30-2008 03:30 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
