Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-01-2009, 06:02 PM   #1
Default Stucco exterior walls - how to properly install doors and windows?
I am remodeling my home, and planning replace an existing patio door and existing window - both windows openings will be resized and reframed appropriatly. I also will be installing a new exterior door where there is now not a door, with the appropriate opening cut and framed.
I have a stucco guy at the ready to handle whatever patching is needed.
The question I have is how does one deal with the thicker than normal walls due to the stucco exterior? The door jam will leave about 3/4" from their outer edge to the surface of the stucco walls.
Similar question for the windows, the affixing them via the nailing flange to the 2x4 framing will leave them set back from the outer edge of the stucco walls as well.
I am missing something obvious?
thx!
Vince
vsheetz is online now   Reply With Quote
Old 02-01-2009, 11:28 PM   #2
tomstruble's Avatar
get the units with a stucco fin
tomstruble is offline   Reply With Quote
Old 02-02-2009, 12:08 AM   #3
Lots of damage can be caused from an improper installation with stucco. It's a very specialized type of siding and there need to be detailed flashing. Can be a nightmare and cause lots of mold and rot if done improperly. You might want to ask the stucco installer, if he is a professional, for details about it. The stucco wrap, or tar paper has to be overlapped with the flashing to prevent water from getting to the framing.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 02-02-2009, 12:47 AM   #4
A bit of Googling gave me some insight into the stucco fin. I gather the jam is extended out to the edge of the stucco and incorporates a flap that extends over the stucco a couple inches.
I will be removing windows that have a nailing fin - so a have to cut and break away the stucco a couple inches all around to reveal the nailing fin. And then the area this area I remove will be covered by the new window's stucco fin - correct?
Or is there a better way to remove the existing window that does not require cutting so much stucco away?
thx!
More On This Topic
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. What I would do with this exterior is stucco. I have stucco before which is just a mixture of water and cement pour in cement and sand and you just put it on there. I understand... Read More »
Whether you are buying an exterior door for a new construction or you want to replace an older door, it is important to remember that the exterior doors of your home are the first impressions that are made upon your guest. Buying an exterior door is... Read More »
Okay now we are going to do the door frame, still using the number ten brush and we are going to do this window frame up here too. It is a little thicker than the door frame and we are going to add a little bit of red to it, so we get an orangier version... Read More »
Rodents such as mice and rats, are most likely to enter a building as the weather turns colder and frost starts. Their outdoor habitats may not protect them from the weather and their food source runs low as well. They are attracted to the heat within a... Read More »
Help! Mismatched Trim, Doors, Windows - Paint them All??? Snowy334 Interior Decorating 12 06-30-2009 04:26 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 11:01 PM
preparing windows and doors for brick veneer. rustic Carpentry 0 11-11-2008 11:40 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 07:04 PM
Furring out windows and doors for vinyl siding install...new construction... MoparAutoworks Building & Construction 0 08-10-2006 12:57 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
