#1 |
Stripping Service?
No, not as interesting of topic as it sounds. Are there places you can take larger wood peices (shellaced doors in my case) to have them stripped? Not the meticulous (and I'm sure very expensive) kind of hand stripping you might get for antique furniture but something more industrial and cheap. I didn't find much in my google search but maybe I didn't know what to look for.
#2 |
Contractor - Renovations
Stripping Service?
there are places that will actually dip the stuff into a tank.
not sure how you'd google it either, and most of these places probably wouldn't be online anyway. best bet is to ask around with guys who do historical restoration work maybe. some guys will take old doors to places like that.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ::. .:: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. :: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ::. |
#3 | |
Stripping Service?Quote:
Ron |
| The Following User Says Thank You to Ron6519 For This Useful Post: | fungku (02-05-2011) |
#4 |
Stripping Service?
I've been working on editing some video tutorials and hit a few snags. Thought I could find lots of advice online so I did a google search for "home made videos"...
![]() a new lesson "think before you search"
#5 |
Super Moderator
Stripping Service?
Put your location into your profile----you need a shop but we don't know where---
There are strippers---many went out of business because of tougher EPA regulations---however there are some still around.---Mike--
New members: Adding your location to your profile helps in many ways.--M-- |
#6 | |
I was just working on a thread seeking advice about what to do about all my doors and trim that's in craptacular shape. This was just one idea. |
#7 |
Stripping Service?
I never recommend dip-n-strip. This process often softens the glues holding the doors or furniture together, and seriously raises the grain on Oak among others.
#8 |
gravity always wins
Stripping Service?
I agree. I've seen doors come back from these places that had a serious hurtin' put on them by the process.
#9 |
Stripping Service?
they went to the strippers and came back with something?
hmmm...
#10 |
Stripping Service?
Thanks for the replies. So if I dont' end up doing this with the doors, what about metal? Most of the vent covers and housing are lousy with multiple layers of chipping paint. Might be nice to strip and refinish them. How would I go about finding such a place?
#11 | |
Ron |
#12 | |||
Stripping Service?
here is a snippet from some other people I trust who had talked about it last year
... Quote:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ::. .:: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. :: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ::. Last edited by fungku; 02-07-2011 at 05:07 PM. |
#13 |
Stripping Service?
I've sent a LOT of stuff to my local dip stripper in Wilmington, DE. I know, it's way too far for you, but they are called "R & R Dipping" on the 200 Block of Scott Street. There's "Right stuff" and "Wrong stuff" to have dip stripped. These guys will do antique furniture and refinish it if you've got the cash, but I've only sent them:
- Doors (yes, many have come back without the glue, especially the ones with thick paint that sat in the vat for way too long.) - Whole house of Trim Casing - Somehow the long side of the corners got longer, and the short sides got shorter. So lots of it had to be re-cut or ended up with a "V" in the corners of the windows. - Cast Metal ducting registers. There's no better solution than paying $15 per register. I clear coated them and it keeps them from rusting. They look grate! (pun intended). - Door hinges and hardware: the brass coated stuff gets ruined. The solid brass is worth it. Pretty much everything came back with little chips of paint that still needed to be scrapped out of the corners. If you are looking to remove a finish and stain the wood. I'd suggest it. I paid about $40 per door to have them dipped in bulk about 10+ years ago, but last time I dropped off an individual door it was $75-80. I think they changed their chemicals too. If I'm re-painting, these days I just sand and slap on a new coat. It's not worth it in my opinion if you are going to re-paint the stuff. |
| Display Modes | |
| Wiring Size Calculations for New Service | CorinthWest | Electrical | 7 | 12-07-2010 12:36 PM |
| Service mast options | bsperr | Electrical | 6 | 12-09-2009 09:48 AM |
| Remodel - Moving from 200 amp service to 320 amps | stevedar | Electrical | 20 | 11-29-2009 09:14 PM |
| Lennox service valve questions | leeh1212 | HVAC | 8 | 07-25-2009 01:20 AM |
| Grounding for two service entrances to same house. | jogr | Electrical | 18 | 09-24-2008 11:31 AM |
