-   -   Stripping Service? (http://www.diychatroom.com/f14/stripping-service-94620/)
Ptron 02-05-2011 01:45 PM
Stripping Service?
No, not as interesting of topic as it sounds. Are there places you can take larger wood peices (shellaced doors in my case) to have them stripped? Not the meticulous (and I'm sure very expensive) kind of hand stripping you might get for antique furniture but something more industrial and cheap. I didn't find much in my google search but maybe I didn't know what to look for.
fungku 02-05-2011 02:00 PM
there are places that will actually dip the stuff into a tank.
not sure how you'd google it either, and most of these places probably wouldn't be online anyway.
best bet is to ask around with guys who do historical restoration work maybe. some guys will take old doors to places like that.
Ron6519 02-05-2011 06:47 PM
Don't worry about the "stripping" search, I'll do it. I'll get back to you with the results.
Ron
fungku 02-05-2011 07:02 PM
I've been working on editing some video tutorials and hit a few snags. Thought I could find lots of advice online so I did a google search for "home made videos"... :laughing:
a new lesson "think before you search"
oh'mike 02-05-2011 07:09 PM
Put your location into your profile----you need a shop but we don't know where---
There are strippers---many went out of business because of tougher EPA regulations---however there are some still around.---Mike--
Ptron 02-05-2011 08:04 PM
Fixed...I think. In case it doesn't show up it's Madison, Wisconsin.
I was just working on a thread seeking advice about what to do about all my doors and trim that's in craptacular shape. This was just one idea.
hayewe farm 02-05-2011 08:10 PM
I never recommend dip-n-strip. This process often softens the glues holding the doors or furniture together, and seriously raises the grain on Oak among others.
Maintenance 6 02-07-2011 12:07 PM
I agree. I've seen doors come back from these places that had a serious hurtin' put on them by the process.
fungku 02-07-2011 12:54 PM
they went to the strippers and came back with something?
hmmm... :huh:
Ptron 02-07-2011 01:03 PM
Thanks for the replies. So if I dont' end up doing this with the doors, what about metal? Most of the vent covers and housing are lousy with multiple layers of chipping paint. Might be nice to strip and refinish them. How would I go about finding such a place?
Ron6519 02-07-2011 01:33 PM
You could have those media blasted or chemically stripped.
Ron
fungku 02-07-2011 04:05 PM
here is a snippet from some other people I trust who had talked about it last year
Originally Posted by ..
Seriously. Look for a furniture refinishing place. They will have a tank that they dip them in. They will strip everything fairly cheap.
Another option if you are just worried about the details areas is media blasting. Someone had a post about blasting antique furniture.
My uncle used to do furniture refinishing for a living.
By hand... try a heat gun, scrapers, dental pics etc...
Originally Posted by ...
... is right about sending them out, but dont let them dip it. It soaks up too much chemical. The place I go to hangs it over the tank and sprays the stuff on.
It will save an incredible amount of time.
In an older door sometimes dipping softens the hide glue holding the door together. I guess it depends on the guy actually doing the work, they know when to take it out of the tank.
There used to be a place where I went to that used vapors above the tank to strip the doors, that worked really well.
I don't think what they can do can be matched by doing it ourselves.
mknmike 02-07-2011 11:55 PM
I've sent a LOT of stuff to my local dip stripper in Wilmington, DE. I know, it's way too far for you, but they are called "R & R Dipping" on the 200 Block of Scott Street. There's "Right stuff" and "Wrong stuff" to have dip stripped. These guys will do antique furniture and refinish it if you've got the cash, but I've only sent them:
- Doors (yes, many have come back without the glue, especially the ones with thick paint that sat in the vat for way too long.)
- Whole house of Trim Casing - Somehow the long side of the corners got longer, and the short sides got shorter. So lots of it had to be re-cut or ended up with a "V" in the corners of the windows.
- Cast Metal ducting registers. There's no better solution than paying $15 per register. I clear coated them and it keeps them from rusting. They look grate! (pun intended).
- Door hinges and hardware: the brass coated stuff gets ruined. The solid brass is worth it.
Pretty much everything came back with little chips of paint that still needed to be scrapped out of the corners. If you are looking to remove a finish and stain the wood. I'd suggest it. I paid about $40 per door to have them dipped in bulk about 10+ years ago, but last time I dropped off an individual door it was $75-80. I think they changed their chemicals too. If I'm re-painting, these days I just sand and slap on a new coat. It's not worth it in my opinion if you are going to re-paint the stuff.
slastarr 03-06-2017 04:58 PM
Re: Stripping Service?
I am in Madison WI which is where you are, I think. Did you find someone in the Madison area to strip your wooden door?
ront02769 03-06-2017 07:02 PM
no one with a REAL antique would take it to a dip and strip place. But if you just want an old door, you could....but be aware that the chemicals used can trash certain types of glue....giving you something that you have to take completely apart and rebuild. Ron
