Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-06-2010, 12:42 PM   #1
Stripped screws in chair
Hello, I am new to the fix-er-up world so pardon my ignorance. I am repairing an old chair and the screws are stipped from their original holes. I need to use the same length screws but I need to put something in the old hole for the screw to adhere to. What should I use...I tried breaking off toothpicks and shoving that in the hole but that didn't work. Is there a product out there that I should buy that will harden enough to give that screw something to bite on to? Thanks in advance
Paul
Paul McMullin is offline   Reply With Quote
Old 04-06-2010, 01:02 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome.
If the screws are out of sight, I'd drill through it a bit bigger, then wood glue/hammer in matching sized dowel, drill pilot hole in dowel and re-screw.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-06-2010, 01:12 PM   #3
Thanks DM that makes sense and even I think I can do that
Paul
Old 04-06-2010, 01:37 PM   #4
the Musigician
Happy to help!
Good luck!
DM
Old 04-06-2010, 03:41 PM   #5
That is your best bet, just making new screw holes. Anything you put in the hole won't really adhere well to the wood, especially after you put a screw back in the hole
lanemiller is offline   Reply With Quote
Stripped out door hinge screws krankykitty Carpentry 23 01-16-2012 10:23 PM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
stripped screws econdave General Discussion 8 07-07-2009 06:23 PM
