Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-19-2012, 06:49 PM   #1
stringer pulling away from walls(basement stairs)
My stringers have pulled away from the walls, is there a way to fix this? There are no loose treads. Any advise is greatly appreciated.
thanks
Moe9990 is offline   Reply With Quote
Old 08-19-2012, 06:55 PM   #2
Now how would anyone know what's wrong and how to fix it without a single picture?
Post some and lot's of people here will be willing to help.
Old 08-19-2012, 07:54 PM   #3
please see pics attached
stringer pulling away from walls(basement stairs)-imgp0052-600x800-.jpg   stringer pulling away from walls(basement stairs)-imgp0051-600x800-.jpg
Old 08-19-2012, 08:07 PM   #4
That's called the skirt, not the stringer. The stringer is what's under the stairs supporting the treads.
If you can find a stud you can predrill and counter sink holes in the skirt and use ceramic coated 2-1/2 decking screws. to pull it tight.
You can also add base cap moulding to give it much better finished look.
http://www.woodworksofpeoria.com/base-cap-molding
Old 08-19-2012, 08:38 PM   #5
STAFF
BigJim's Avatar
If these stairs are wall to wall and not open one side it would do more harm to pull the stringer/skirt to the wall especially if it is a mortise stairs. If it is open one side then there shouldn't be any problems pulling the stairs to the wall provided you pull the entire stairs not just the stringer/skirt.
You will have to push the stairs back against the wall before installing screws, screws alone will not pull that entire stair case.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 08-19-2012, 11:17 PM   #6
AHH, SPANS!!!
thanks
I think countersinking with the screw will work, just do not pull the skirt trim board in with the screw to far. Drill the screw slowly so that it does not pull the skirt trim up to tightly to the wall. A good grab into the wall stud with screws to pull the trim in some would help keep the trim from pulling away from the wall.
Tip- A simple way to find a wall stud is to tap the butt end of a hammer against the wall and listen for the solid sound, it will sound more hollow between the studs.
hand drive is offline   Reply With Quote
Old 08-20-2012, 06:30 AM   #7
Moderator
kwikfishron's Avatar
thanks
Is that just a half wall?
Could you post a picture standing back at the bottom of the stairs showing both sides in the same shot?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Box steps or stringer for a deck stairs drtbk4ever Building & Construction 2 05-15-2012 10:54 AM
Exterior Stairs to Coach House Need to be Repaired/Replaced. Help Appreciated! 2031pratt Carpentry 9 04-07-2010 03:43 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
