Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-13-2011, 02:34 PM   #1
Stringer Hanger Board Attachment on a Deck
Hi all,
The concrete landing pad below the stoop in front of my house subsided considerably, so I whacked it out of there and am replacing it with a 4' x 8' deck as the 'bottom step' of the stoop, and then a two step run of stairs off the deck to the driveway.
I will be using 2 x 6 joists and the first step of the stairs is directly off the deck, so I will have to install a hanger board to attach the stair stringers. I've read many ideas about how to attach a hanger board to the rim joist, and am not thrilled with any of them. However, if I lay out my posts and beams the right way, I will be able to attach the hanger board directly to the post and ends of the beam.
My question is whether this is okay to do, or if anyone can see any potential problems with doing so.
Rusty S. is offline   Reply With Quote
Old 10-15-2011, 07:30 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
my first question is what size joists do you have on the upper deck which the stairs are coming off fof
what i do on all deck stairs i build is that i cut a notch in the inner stringers the size of a 2x4 on edge both at the top back of the stringer and at the bottom front edge of the bottom riser. this allows to let in a 2x4 both at the top and bottom of the stringers so that i can assemble the stringers as a unit first then i drive screws through the upper let in 2x4 into the rim board of the deck.
when im ready to hang the stairs the first thing that needs to be done is to install vertical blocks from the back of the rim board so to install another piece of 2x4 or 2x6 under the rim board which acts as additional backing for the stairs just depending on the height of the risers. this allows the stairs to be at the exact height for all risers to be the same.
woodworkbykirk is offline   Reply With Quote
Tags
deck, stairs, stringer hanger board
5/4 x 6 or 2 x 6 PT Decking, what would you choose? Quicksmoke Building & Construction 9 08-23-2011 09:17 PM
Ledger attachment for deck. Clutchcargo Building & Construction 9 06-11-2010 10:49 AM
Deck Board Gap? cibula11 Building & Construction 22 06-25-2007 11:11 AM
Hide deck board ends bardad1022 Carpentry 4 06-08-2007 09:55 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
