Strappout Catherdral Ceiling Question. - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By ront02769
Old 01-14-2017, 05:57 AM   #1
Rewards Points: 51
Strappout catherdral ceiling question.
Hi,
Im strapping out the cathrrdral ceiling with 1x3 under scissor trusses. Should i start at peak or sides to measure for 16" centers?
Sent from my SGH-I337M using Tapatalk
deepstuff is offline   Reply With Quote
Old 01-14-2017, 06:36 AM   #2
Property Mgt/Maint
Rewards Points: 1,572
Re: Strappout catherdral ceiling question.
If this is strapping for drywall, usually its installed from top edge working down.
So start at the peak is what I would do
Yodaman is online now   Reply With Quote
Old 01-14-2017, 06:43 AM   #3
Rewards Points: 51
Thanks. In a garage so maybe for drywall maybe plywood or osb?
Old 01-14-2017, 06:50 AM   #4
jlhaslip's Avatar
Rewards Points: 2,818
Just curious about why you would strap out the ceiling for sheet goods?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 01-14-2017, 07:00 AM   #5
Rewards Points: 51
Not sheeting right away. Space for wires, Trusses arent spaced exactly....
Old 01-14-2017, 06:01 PM   #6
Rewards Points: 484
Where I am we strap out everything.and it doesn't really matter where you start. R
deepstuff and woodworkbykirk like this.
ront02769 is offline   Reply With Quote
Old 01-15-2017, 10:07 PM   #7
Registered User
Rewards Points: 526
I usually check overall length for division of 4', OSB at 3" wide rip doesn't sit still for long if a vehicle parks there (humidity).... install waxed side toward you.
Gary
VERY Quick Ceiling Fan install question! Fox Electrical 11 03-23-2014 12:56 AM
help me with my drop ceiling question Shawn Bellanca Remodeling 7 05-10-2013 10:50 PM
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 10:25 PM
Newb DIY'er -basement drop ceiling question mike dub Remodeling 3 02-18-2013 07:37 AM
Ceiling Fan Installation Electrical Question Rafterman414 Electrical 4 01-06-2013 09:25 PM
