Storm Door Queston - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 07:55 AM   #1
Storm Door Queston
I have installed probably 15 or so storm doors. I have always had a tough time getting the closer to pull the door closed when the exterior door is also closed. I think it's got something to do with the air resisting it more than my inability. I have adjusted the closer by turning the screw, adjusted the bottom piece, etc. The only thing I have found that helps is to open the glass, so that ir can get pushed thru the screen. Any other tricks someone can share?
thanks
brokenhammer is offline   Reply With Quote
Old 08-15-2010, 08:29 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
STRANGE.... Most closer brackets have two mounting holes. One for use with the screen, the other for use with the glass in. Are you paying attention to this when you do your install, perhaps this is your problem
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-15-2010, 10:42 AM   #3
Rewards Points: 5,336
thanks
If the door was installed correctly, this is exactly what happens. The "air pillow" is contained between the 2 doors and has no place to go when the main door is closed.
Your solution is one way to get the door to close. The other is to close it manually if it stays ajar.
Ron
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 08:17 AM
Storm Door Handle Installation jogan General DIY Discussions 3 06-09-2009 09:57 PM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-21-2008 11:37 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
