Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-05-2011, 02:03 PM   #1
storm door frame
The top of the storm door frame has rotted through and needs to be replaced. The sides of the storm door frame are in-tact. How do I replace the top support frame? Do I need to remove the entire door from the frame, replace the top support and then re-screw the storm door to the frame again?
vcerilli is offline   Reply With Quote
Old 11-05-2011, 03:35 PM   #2
Old School
Willie T's Avatar
storm door frame
Usually.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Ron6519 (11-05-2011)
Front Storm Door Won't Latch sciron General Discussion 6 02-21-2011 10:47 AM
34" Wide Storm Doors Custom Size Only? kc27 Building & Construction 3 12-08-2010 01:34 PM
Storm Door Selection/Brand Advice Wanted kc27 General Discussion 3 10-25-2009 09:17 AM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-22-2008 12:37 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
