Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-10-2008, 03:50 PM   #1
Stop a door from drifting open?
My bedroom door is very annoying and I've tried everything I could think of to stop this. It's a lightweight wooden door so I'm not sure if it's hollow or not. Problem is if I want to leave it slightly open it drifts so much that it's wide open again. No wind is blowing in my home from what I can tell. The furnace is off doing the day, no windows are open.
Sliding Man is offline   Reply With Quote
Old 11-10-2008, 03:57 PM   #2
the Musigician
DangerMouse's Avatar
seems to me it's gravity.... door's not flush&plumb.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-10-2008, 04:05 PM   #3
Simply remove one of the hinge pins. Lay it on a hard surface (sidewalk, basement floor) and hit it with your hammer causing a slight bend in the pin. Replace the pin and the door will stay where you put it.
hompac is offline   Reply With Quote
Old 11-10-2008, 08:36 PM   #4
You can either do that or just plumb up the door.
kevin211mvd is offline   Reply With Quote
Old 11-10-2008, 08:56 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
OR put thins shims behind the hinges as necessary to plumb it up. (I use used utility knife blades).
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-10-2008, 09:55 PM   #6
Man of many hats
wrangler's Avatar
Or if you have a dead pet just laying around the house you can use that as a door stop.
But seriously, yes, your door is not plumb. Sometimes when an inexperienced door installer installs a door, they are more concerned with having an even 'reveal' (even gap) around the door, than having that AND having it plumb and level. Gravity will cause an unplumb door to try and shut(or open) on its own. The Best solution is to reinstall it correctly. If you try to adjust the bottom hinge out to rectify this, then you will probably have the door slab hit the jamb on the opposite side. If the installer only 'pin nailed' or tacked the door in, you may be able to do this, and then use a block of wood to offset the opposite side, but you will also have to use that same block against the corner diaganally opposite from that same hinge.
Not sure if I described this well, but if not just ask.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 11-10-2008, 11:06 PM   #7
General Contractor
wrangler , you made me laugh very loud. good job. Wher can I find a dead pet.
Hompac, you hit the nail on the head. Just bend a hinge pin( or 2) and that will do the job for the quick fix. Obvoiusly the right tinng is to rehang the door or jack up the house on one side.
Illinois G.C. is offline   Reply With Quote
Old 11-11-2008, 04:27 AM   #8
the Musigician
and if these suggestions fail, you can simply change the gravitational pull of the earth until the door hangs right.
DM
Old 11-11-2008, 08:49 AM   #9
Global warming is the cause. And it will only get worse as sea levels rise.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-11-2008, 09:33 AM   #10
retro is offline   Reply With Quote
Old 11-11-2008, 10:12 AM   #11
look out for those 'free cats' with a stripe down there back. (Usually black and white models) use those and you MAY need a few of those Glade plug in jobbies AND a few bottles of frebreeze
personally I would prefer a god old dead possum or raccoon,,,long as they arent pizza'ed too thin!!
4just1don is offline   Reply With Quote
Old 11-11-2008, 10:50 AM   #12
the Musigician
mmmmMMMmmmm streetpizza! roll 'em up and pop 'em in the oven!
DM
Old 11-12-2008, 10:37 AM   #13
gravity always wins
Frisbee cats don't make good door stops. The door tends to drift over them.
Maintenance 6 is online now   Reply With Quote
Old 11-12-2008, 09:34 PM   #14
I second that. Best simple fix. If necessary bend a few of the pins. Most likely the wall the door is hung in is out of plumb and plumbing the door will cause you a whole new set of complications and details to fix.
DonV is offline   Reply With Quote
Old 11-15-2008, 07:28 PM   #15
@ some of the comments! I just bent one of the pins and now the door doesn't move. Man 1 Door 0
low slope roof want stop leaking kaju Roofing 22 09-14-2012 01:19 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
garage door open light deck hand Electrical 3 01-22-2008 09:29 AM
Hinge door stop fred2007 General Discussion 3 11-11-2007 08:00 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
