Steel Wire Deck Railing - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 12:30 AM   #1
Steel wire deck railing
I'm replacing a deck post that has horizontal stainless steel wire running through it. I have to remove the wires, drill holes in the new post and replace the wires. How do I ensure that the drilled holes are centralised and horizontal? And can I re-use the wires? How do I unclamp and re-clamp them?
Derrick41
Derrick41 is offline   Reply With Quote
Old 09-04-2009, 07:26 AM   #2
I have never done wire rails, but have seen them done. There is usually a turnbuckle somewhere in each line to tension the wires. Unscrew that and all comes loose. Using a drill press is one way of drilling exact holes. Another method is a drill with a level built in.
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
Deck railing posts sandyman720 Building & Construction 7 05-29-2008 03:53 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
