Steel Studs ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-23-2006, 02:58 PM   #1
Steel Studs ?
Help Please!
I am in the process of installing a chair rail, HOWEVER during my search for studs and my apparent failure to locate any of the wooden variety I came to the realization that my home is a steel frame construction and in my ignorance forgot that the studs would be steel. What options do I have for tacking the chair rail (or any moulding for that matter) to the wall as I guess finishing nails are out of the question?
Many Thanks in advance for your expert advice!
Steve
Steve is offline   Reply With Quote
Old 11-23-2006, 08:46 PM   #2
Master Craftsman
Big Dave's Avatar
They make small trim head screws which would be your best bet. Predrill and countersink the head and fill.
Here is a link. http://www.shop.com/op/aprod-p379580...ad+screw-nover
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 11-23-2006, 09:12 PM   #3
Steel Studs
Thanks a million Dave, your response much appreciated!
Old 11-24-2006, 05:10 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You might also want to use some adhesive along with the trim-head screws....
- Build Well -
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
