Steel Entrance Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 11:55 AM   #1
Purchased 2 new pre hung steel entrance doors and had them installed by a carpenter....now we are getting leaks in both bottom corners when ever it rains.
D. Hubble is offline   Reply With Quote
Old 04-04-2011, 12:19 PM   #2
Carpenter
dtsman's Avatar
Can you determine if the leak is above or under the threshold?
Maybe use a water hose to find the exact spot so you can determine if it is an installation problem the carpenter should fix, or a defect in the manufacturing of the door.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 04-04-2011, 12:51 PM   #3
Rewards Points: 78
And the carpenter said ...? Seriously, I assume that you paid for an installation with the thought that it would not leak, so I would certainly give him or her the opportunity to make it right. Assuming they do, it's a win, win situation; you don't need to repair the problem, and they will have a satisfied customer.
Old 04-04-2011, 02:18 PM   #4
concretemasonry's Avatar
Rewards Points: 2,594
D. Hubble -
Keep in mind that you are only seeing where water shows up in the building and not where it is leaking in. The actual entrance could be anywhere above or to the side of the "apparent" leak location.
Improper installation of doors and windows is far more common (65%) than people realize. Did the carlenter do anything about continuing the flashing above (or on the sides) or continuing it under the primary moisture barrier. Water could the coming down the outside of the moisture barrier and get funneled around the frame intil it can find a place to come out. Doing it the same way we always did is not a cure-all.
Dick
concretemasonry is online now   Reply With Quote
DIY Paint New Steel Exterior Doors hellothere123 Painting 17 02-02-2010 05:59 AM
steel vs wood garage doors rocketdoctor Building & Construction 10 09-17-2009 05:35 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
painting side by side front steel doors old salt Painting 3 06-04-2008 08:18 AM
