Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-01-2006, 08:23 PM   #1
NewBob
Steel Dog
How 'bout an elementary answer to an elementary question for an elementary woodworker. What is the purpose/function of steel dog that moves up and down on the front jaw of a woodworker's vise? You would not believe how many people I have ask this question including seasoned cabinet builders and house builders, with no results.
This is my first time here and I just attempted to attach some pictures to this thread so you guys can see what I'm talking about --- I have no idea if they are attached or not and don't know how to find out.
Robertgn is offline   Reply With Quote
Old 12-01-2006, 08:34 PM   #2
HarryHarley
HarryHarley's Avatar
Steel Dog
When the vise is properly afixed to the side of your woodworking table that also has a series of movable "dogs", you can lay a board between the two dogs closest to the size of the board you are working with, snug it up with the vise and work on a stable piece of wood.
Be it planing, sanding, etc.
HarryHarley is offline   Reply With Quote
Old 12-01-2006, 08:43 PM   #3
NewBob
Steel Dog
I understand what you're talking about Harry---from what you're saying the top of the vise jaws should be mounted such that the top of jaws are flush with the table top in order to utilize the steel dog properly.
Thanks a lot.
Old 12-02-2006, 06:59 AM   #4
Steel Dog
Exactly Right!!!
mdlbldrmatt135 is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Pros/Cons of Steel Siding moneymgmt Building & Construction 2 06-19-2007 03:57 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
steel under shingles orlockorlok Roofing 8 05-30-2007 09:44 PM
Steel Beam or Wood Reinforcement for 2nd floor addition? coralhead1 Building & Construction 2 06-06-2006 02:22 PM
