Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-23-2009, 07:54 PM   #1
Default Steel brackets on wall studs
I am replacing one of the 2x4 studs in my garage wall, and I wondered if it were code to use those galvanized steel brackets & screws instead of toe nailing?
The brackets should be easier since they can be attached to the stud before it is put in place. Another stud is close by which makes nailing harder.
tns1 is offline   Reply With Quote
Old 08-23-2009, 09:22 PM   #2
Building codes guy, Mod
thekctermite's Avatar
No, code makes no provision for anything but nailing the studs in place, either by toenailing or face nailing through the plates (not an option for you). Screws, brackets or any other means of mechanical attachment isn't prescribed by code...Therefore, generally speaking not allowed.
Will it make a difference? Probably not. It is one stud. You only have to toenail from one side, not both. Even if there's another stud in the way on one side, is the other side open enough to allow nailing? You can cut a spacer block to put between the new stud and the close stud to keep it from moving when you nail it in if you need to.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 08-23-2009, 09:59 PM   #3
It sounds like the code has fallen behind the technology. I think there must be an alternative to nailing which is just as strong.
I am moving the stud to replace a breaker panel so I expect it will be inspected. Even if I can't use the brackets I'd much rather use screws instead of nails to make it easier to remove if needed. I suppose that isn't code either?
How many nails and what gauge are needed for studs?
Is pre-drilling allowed?
Old 08-24-2009, 09:51 AM   #4
No, screws are not recognized by this application because of good reason. They just are not as strong.
3-8's or 2-16's are required for nailing. If for some reason you feel you need to pre-drill I don't see any reason you couldn't do that.
Old 08-24-2009, 03:53 PM   #5
After a bit more reading I think the argument goes that the screw is stronger than the nail in a straight pull-out test, but in a bending, shear or shock test the nail will bend quite a bit more before failing, where the screw is not as malleable and will snap.
Nails it is.
Old 08-24-2009, 05:58 PM   #6
Correcto!
Old 08-25-2009, 08:52 PM   #7
The hardness of the metal also comes in to play. Most screws are harder than nails. Sounds like harder is better until you consider it will break (snap) where the nail may bend.
Rege
RegeSullivan is offline   Reply With Quote
More On This Topic
This is Rob McManhon for Expert Village. The other method for nailing is toenailing. This is really only used when your plate has to be already in place and it's impossible it would be sitting on the floor so there is no way that you can get up from... Read More »
Toenailing with a Nail Gun
Toenailing with a Nail Gun by Expert Village
This is Rob McManhon for Expert Village. Now when you are toenailing because you don't have the strength coming right through you want to have at least four nails, so that if any pressure hits this way or this way it is not going to kick your stud over... Read More »
Buffing the toenails is a very important part of a pedicure. In addition to helping you get rid of dry and dead skin, buffing smooths the ridges of the toenail surface, while ridding ugly discolorations from your toenails. Follow these steps to buff... Read More »
I'm Lillian with Expert Village and we have now completed pushing the cuticle back and trimming the excess cuticles so now I'm going to demonstrate buffing the toenails and talk a little bit about the yellowing of a toenail. Next I'm going to pick up the... Read More »
My name is Anneka, and on behalf of expertvillage.com, in this clip I will be showing you how to file your nails after clipping them during a pedicure. After we have gotten our shape which would be straight across, we have to round the edges using our... Read More »
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 07:10 PM
Boxing beams and ducts with steel studs Chemist1961 Building & Construction 3 06-15-2009 11:55 AM
how to find studs in shower wall oldrocko General Discussion 1 03-10-2009 09:35 PM
Leveling a ceiling with steel studs tomtbone Building & Construction 0 05-27-2008 07:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
