Standard Home Bar Sizes? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 06:35 AM   #1
Woody10's Avatar
Rewards Points: 29
I was wondering if anybody has any input into standard home bar sizes. I am building a very simple frame for my project.
I am building the front (patron side) 43" tall which appears to be standard.
I am not sure how wide my server side ledge should be or how high off the ground it should be. I do want to put a small sink in as well.
Here is my frame. I plan of putting horizontal piecs off of each stud for my sever side shelf to sit on and then build it down to the ground on the other side.
Woody10 is offline   Reply With Quote
Old 05-25-2011, 07:06 AM   #2
kwikfishron's Avatar
Rewards Points: 176
I don’t know that there is a standard bar length. How much room do you have to work with? How many seats do you want? I don’t use any horizontal pieces. You do need a return wall on the ends if it’s open on both sides. The top including server shelf is done with double ¾” plywood (at least that's how I do it) assuming you don’t have a large slab of something you’re using for the top.
kwikfishron is online now   Reply With Quote
Old 05-25-2011, 04:34 PM   #3
Woody10's Avatar
Rewards Points: 29
It's not the length I am after. The length will be what it is.
It's the height and depth of the server side counter that I am concerned with.
Old 05-25-2011, 05:39 PM   #4
Rewards Points: 176
43” is a good finish height, 24” on the top is usually plenty but you can go more. In a commercial setting the bartender usually has 24” of sinks and coolers under the bar so a top over 2’ can make it difficult for them to reach over and clean up your spilled drink. A 10-12” overhang on the patron side is comfortable. Server height is usually ¾” under bar height and about 5-6” deep.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Are kitchen cabinets standard sizes? Yeti Remodeling 8 01-30-2009 03:20 AM
Non Standard Ductwork Sizes bigbavarian HVAC 1 07-10-2008 04:26 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
