Stairway Skirtboard - Carpentry - DIY Chatroom Home Improvement Forum
View Poll Results: How easy is it to install stairway skirtboards?
0=easy to 5=hard 0 0%
DIY beginners can do it; some experience necessary; hire a professional carpenter 0 0%
Voters: 0. This poll is closed
Old 07-19-2010, 10:03 PM   #1
Stairway skirtboard
One of our members had a good idea for designing and using a stairway skirtboard template. However, I need to know more of the A-Z details on building and installing stairway skirtboards. Please, any help appreciated.
YEVRAH is offline   Reply With Quote
Old 07-19-2010, 11:35 PM   #2
you need to be more specific.
are you referring to a mitered skirtboard for an open staircase, or a wall skirtboard? if it's going against a wall and the stairs haven't been built yet, it's as easy as simply nailing up a piece of trim in the right place with the right angles mitered on the ends.
if it's trying to be retrofitted or if it's a mitered skirtboard being built i would put this task in the "very challenging" category if you want to pull it off in a way that looks pro.
it's pretty much all about marking the board in place with either a site-built "preacher", or compass/pencil or whatever works, and then very carefully cutting it.
you need to provide more info on what you're looking to do, and/or go out and by a book on how to build stairs.
wombosi is offline   Reply With Quote
The Following User Says Thank You to wombosi For This Useful Post:
YEVRAH (07-20-2010)
Old 07-20-2010, 01:31 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I agree with schmolze, we need more details as there are just too many different applications for skirt boards as there are so many different styles stairs. Also note if the skirt is for a left hand open stairs with a mitered skirt, you will need a left hand circular saw. I know this sounds like a joke but there is a left handed circular saw, I have two of them.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
YEVRAH (07-20-2010)
Old 07-20-2010, 06:22 AM   #4
kwikfishron's Avatar
Rewards Points: 224
Post some pictures.
kwikfishron is online now   Reply With Quote
Old 07-20-2010, 09:35 AM   #5
You are so right! I'll figure out how to up load a picture or two. Thanks for the heads-up.
Old 07-20-2010, 10:24 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
YEVRAH, this is the way I post a picture. When you hit reply to post you will see the box where to type your message, if you scroll down a little you will see a box that says "manage attachments". Click on that box and upload from a file where the picture is and there ya go. You may have to resize your picture.
Jim
YEVRAH (08-03-2010)
Stairway skirt board template - easy Richo Carpentry 14 08-26-2011 05:03 PM
R311.5.2 HEADROOM stairway code in Michigan question DoobieG Building & Construction 13 01-29-2010 06:55 PM
Finishing basement stairway Richo Carpentry 26 03-09-2009 05:28 PM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
Stairway loose asegal General DIY Discussions 4 12-02-2006 05:00 PM
