Stairs For A Converted Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 08:56 PM   #1
Stairs for a converted garage
I have one-car garage that was converted into a living room. I'm looking to replace the staircase into the main living area because it's too steep and doesn't have a railing.
I was hoping to find some type of modular kit that would be easy to install. Problem is that the only kits I can find are for full size staircases when I only need 3 or 4 steps. Any ideas on where to look?
tworrell22 is offline   Reply With Quote
Old 07-01-2012, 09:01 PM   #2
Rewards Points: 13,300
Post a picture of your old one.
Not that hard to make your own. Or just hire someone to do it, in most cases it would not take a 1/2 day to build, not including painting or stain.
There's lots of info on the net on how to do it, for the stringers just Google "stair tread layout".
Old 07-03-2012, 06:48 AM   #3
Stairs are heavily regulated in building codes, and they need to be. They are the main source of tripping/falling accidents. Total riser/tread dimensions should be about 18". Tread height shoud be between 7" and 7 1/2, depth about 9". A few steps should not occupy too much space, but for more, I might suggest a circular staircase.
Old 07-03-2012, 01:40 PM   #4
Rewards Points: 79
Even better still is if the risers are less than 7 and the treads are about 11. There is an inverse relationship where when you make one dimension bigger, the other should get smaller. A good rule of thumb I was taught is that two risers plus one tread=25.
eclark is offline   Reply With Quote
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 08:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 04:08 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 12:02 PM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-26-2009 12:05 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
