Stairs- Carpeting Against Stringer/drywall - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 10:45 PM   #1
Kellster
mjkpainting's Avatar
Rewards Points: 77
Stairs- Carpeting against stringer/drywall
I am finishing my basement and planning on installing a molding between the stair stringer and drywall. I'm concerned how the carpeting is going to butt up on the end of the stringer. I can't seem to visualize it.
Of course my wife removed every bit of carpeting in our house
My question
Where and how does the carpeting end on the stringer??? Is it bound????
What type of molding should I use to close the gap between the drywall and the top part of the stair stringer????
You guys always come through
mjkpainting is offline   Reply With Quote
Old 09-13-2009, 12:33 AM   #2
Registered User
Termite's Avatar
I'm thinking your terminology might be off here. The stair stringer is the 2x12 that forms the structural backbone of the stair. The treads are what you step on (and what I think you're talking about). The risers are the vertical pieces between the treads. The skirtboards are diagonal 1x material that the treads and risers are let into, as opposed to butting the drywall.
If your treads and risers butt into the drywall without a skirtboard, you might consider a simple base cap moulding on top of a 1x2 to dress it up and give the carpet something to butt to. Base cap looks great on top of a 1x. You'll of course have tack strip at all the edges.
If there's no 1x skirtboard, these stairs are going to be a real nightmare to trim, as well as a challenge to keep the drywall/paint alongside the treads in good shape.
Pics would help for sure!
Old 09-13-2009, 09:18 AM   #3
Kellster
Rewards Points: 77
Some pictures
Thank you for the info and advice. Here are some pictures.
Is that lip on the top of part of the 2X12 (stringer) called the skit board??
After I finish drywalling the walls and install the base cap molding on the skitboard- I am going to have someone install carpet.
When I have the stairs carpeted will they carpet the inside of that 2X12 (stringer)? Where will that carpeting end in relationship to the base cap molding??
Stairs- Carpeting against stringer/drywall-img_3046.jpg   Stairs- Carpeting against stringer/drywall-img_3047.jpg   Stairs- Carpeting against stringer/drywall-img_3048.jpg
Old 09-13-2009, 10:49 AM   #4
Drywall contractor
Rewards Points: 1,070
The carpet will butt to the skirt board with no problem. It will kill below the top edge of the skirt board. (That's the 1" piece running the length of the stairs). The proper way to finish the top edge of the skirt board is, as mentioned above, with a piece of base cap which is available at your local material supply......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-13-2009, 11:35 AM   #5
Kellster
Rewards Points: 77
Thank you
Perfect- Thanks to both of you for the explanation.
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 4 12-01-2011 05:55 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
Need to carpet hardwood stairs clasek Flooring 7 04-21-2009 11:00 AM
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 08:58 AM
