-   -   stairs to the beach (http://www.diychatroom.com/f14/stairs-beach-37860/)
misterc 02-08-2009 07:40 AM
stairs to the beach
I have searched the internet for help with this problem , but have not been able to find any information at all.I hope someone out there can help.
I have a seaside cottage with 15 foot high bank down to the beach. I would like to build a set of steps down to the beach. Because it is on the ocean I will need to remove them in the winter.
With such a high rise I can't use stock lumber for my stringers. My stringer will need to be about 24 ft. I have been thinking about laminating plywood but I don't know how well this will hold up.
I need to either build a set of stairs light eough to take them up in the fall and put them back down in the spring, or find some way to raise and lower them using some kind of winch or pulley system.
If anyone has any suggestions they would be greatly appreciated.
MisterC
Bob Mariani 02-08-2009 09:48 AM
Just make the treads and no stringers. Form and compact the ground to create the steps. Now attach the treads with a rope system to create the stringers. For removal just pull up the rope and stack the treads.
gregzoll 02-08-2009 04:26 PM
The Footings for the stairs may have to be drilled quite a depth, so that the footings do not shift if high water tides. Something like this, really needs an engineer to give you direction. Not something a homeowner can do on their own.
II Weeks 02-08-2009 04:44 PM
what do your new neighbors have?
Scuba_Dave 02-08-2009 08:09 PM
Usually you aren't allowed to dig footers on the beach, even if you own the property. Make 2 pieces of stringers, each 12' long
Then bolt a 16' reinforcement & a 8" reinforcement on each side
Some friends of mine live near a beach & the neighborhood builds stairs. The top end has wheels, stairs are lifted & wheeled back from the ocean. Takes a few people to do this. Another option is electric winch to pull them up
Ron6519 02-09-2009 01:05 PM
Why don't you just carve the stairs into the side of the hill?
Ron
