Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-16-2013, 06:12 PM   #1
n2omichael's Avatar
Rewards Points: 115
Stairs
I have to build a set of stairs to go from my cottage's main floor to the new basement, can anyone tell me how to lay them out? I know you can use a framing square, or speed square, I just can't remember how to do it, any other input or ideas would be appreciated, Thanks!!
n2omichael is offline   Reply With Quote
Old 06-16-2013, 06:30 PM   #2
Framing Contractor
Rewards Points: 112
Divide the total height by 8. Round that number up, and divide it into the total height to give you the rise of each step. The run will vary based on home much room you have to work with. I would start with an even number like 10 and see how that goes. If that ends up too far, reduce accordingly.
So just set up your framing square to the rise and run and you are good to go. There are many other variables, but this will give you an idea.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Duckweather (06-17-2013)
Old 06-16-2013, 07:50 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
do not use 8 as the denominator. its too high a rise. 7 or 7.5 are what gives a more comfortable stair to climb
woodworkbykirk is online now   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
BigJim (06-16-2013), Duckweather (06-17-2013)
Old 06-16-2013, 08:24 PM   #4
Rewards Points: 13,270
#1 Please go back and add your location to your profile. Just go to Quick links to edit.
Yes it matters.
There's a lot of codes that need to be followed when building a set of steps, and your going to need a permit and get it inspected.
http://stairs4u.com/stairbuildingcodes.htm
Old 06-17-2013, 09:58 PM   #5
Haverhill Trade 1965
I have always used 7 to start dividing, then use the whole number from that answer divided into the height again, to get the exact size of each riser. Also normally there is one less tread than riser, and the thickness of the tread should be cut off the bottom horizontal cut where the stringers set on the floor.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
kwikfishron (06-17-2013)
Old 06-17-2013, 10:05 PM   #6
[QUOTE=sixeightten; The run will vary based on home much room you have to work with. I would start with an even number like 10 and see how that goes. If that ends up too far, reduce accordingly. [/QUOTE]
If you end up with say 14 risers you would normally have 13 treads. Starting like sixeightten says multiply tread size times number of treads and it gives you the total run. 9 in this case it would be 13 x 10 or 130 inches. then you know if it fits before you lay it out.
Need help with stairs rogers_t Carpentry 11 02-26-2013 12:30 PM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 07:13 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
