Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 05:23 PM   #1
stairs
Building a stairs with two 'runs', that is, there's a landing about 3/4 of the way up to the 2nd floor. I built the first set of stairs (12 steps) at 7 1/2" rise...which I now realize was a mistake. If I keep going with it, the rises for the 2nd run (4 more steps from landing to 2nd floor) will be only 7" a piece. I'm wondering if that will be a problem? Since it is a different run perhaps it will be ok? Any thoughts appreciated. (This is a new self-build construction house.) Thanks.
palmergregory3 is offline   Reply With Quote
Old 03-19-2013, 05:47 PM   #2
Roofmaster
Rewards Points: 2,172
1/2 inch difference in rise is huge when it comes to steps. You really want the rise to all be the same. That is the most important thing. You can really take a header and get hurt badly otherwise.
Old 03-19-2013, 07:31 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
even with a landing the risers have to be within 1/8" to comply with most regions codes. the only time there can be a differnce that much is if its for stairs leading to different floors of the house.
a friend of mine is having a house built as we speak.. the contractor they hired to frame the house doesnt know how to cut stringers.. there wer variances up to 3/4" from one riser to the next.. they failed the framing inspection because of this and now require the stairs to be rebuilt
woodworkbykirk is online now   Reply With Quote
Old 03-19-2013, 07:38 PM   #4
Rewards Points: 13,450
May be time to bit the bullet on this one and hire a pro. Time and time again we've seen many a DIY stair case and so far they all needed to start over.
Old 03-19-2013, 08:27 PM   #5
kwikfishron's Avatar
Rewards Points: 378
I don't see it like that in this case Joe...The guy just built his house and made a mistake on the stairs. Redo and move on.
Some of the most valuable lessons I've learned were from my own mistakes. $$$
A hundred bucks worth of 2x12, better math and less than a day and all's good.
A lesson learned.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Dave Sal (03-19-2013)
Old 03-19-2013, 09:30 PM   #6
best advise I can tell you is adjust your landing layout to get the rise the same for both sets of stringers. remember the human body naturally adjusts to a set of stairs after just 3 steps.
ubcguy89 is offline   Reply With Quote
Old 03-19-2013, 11:02 PM   #7
Thanks for the replies. The problem was that the basement stairs went too smoothly... I actually only cut one of the stringers for the main floor stairs, but it is a nice piece of 5/4 x 12 white oak. Ouch. It's a housed stringer so now I'm wondering if I could adjust the level and plumb cuts and still use it? I'll have to look into that.
Old 03-20-2013, 08:09 AM   #8
No way would I be using 5/4 anything for a stringer!
Needs to be 1-1/2.
On the outside stringers you are adding a 2 X 4 to the bottom of the stringer to space it out away from the wall for the apron and sheetrock, right?
Old 03-20-2013, 08:25 AM   #9
GBrackins's Avatar
Rewards Points: 2,108
I may stir up a hornet's nest, but have your discussed this with your building official. It all depends on your building code.
According to the 2009 International Residential Code a flight is defined as from one landing to another landing, not one floor to another floor. A quick call to your building department can answer your question per the one that makes the final determination.
Now if it were my place I'd redo the stairs. But then I have CDO.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-20-2013, 09:55 PM   #10
I would never use 5/4 for a stringer, and neither should you!
Need help with stairs rogers_t Carpentry 11 02-26-2013 11:30 AM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 06:13 PM
Strengthening stairs with less support HitLines Remodeling 1 10-29-2009 11:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
