This angle is driving me nuts. Look at this pic
http://www.jlmoldingdesign.com/portfolio/shadow_box/shadow_box19/sim_final 005.jpg
How do you cut the lower acute angle on the box? The stair angle is 48 deg and I guess that should be the lower angle.
So if I cut the base cap at 24 degrees on my saw, I get the other obtuse angle on the box (132 degrees).
If you miter at 45 degrees, you obviously get a 90 degree angle.
Seems I would have to miter above 45, but my saw goes up to 48. The only solution I have so far is cutting a 48 degree, and butting the other piece without a miter.
Any suggestions? Thanks.
