Staircase Storage Project - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 05:20 PM   #1
im looking to maximize space and found a few pictures of under-staircase storage that didnt look to complicated.
has anyone here done this type of project before? any suggestions?
seasoned vet is offline   Reply With Quote
Old 08-08-2012, 06:54 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
You need to make sure there is adequate support on the section that the built in is in. It also will take away from your basement stairs...if there is one.
Millertyme is offline   Reply With Quote
Old 08-08-2012, 06:59 PM   #3
Rewards Points: 13,960
If it's left open like that then you need to install 5/8 fire code drywall under the stairs before building it.
Old 09-04-2012, 08:59 PM   #4
That's one of the first projects I did after we bought our house. We were able to leave the existing support members under the stairs, and built plywood cabinets to fit in the remaining space. The A/V gear is all under the stairs now, and the TV is built into the wall to maximize the amount of floor space available.
jeremybrooks is offline   Reply With Quote
Old 09-05-2012, 11:40 AM   #5
thanks for the advice guys.
Out of room..Need a storage shed!!! Gomezy3k Building & Construction 6 12-19-2011 10:27 AM
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-19-2011 11:58 PM
Timbertech Radiance Rail project Ranger1227 Project Showcase 7 07-29-2011 12:59 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Anyone used a project manager instead of GC? pulpit Building & Construction 10 02-11-2011 10:08 AM
