Staircase Remodel: Removing Riser - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 05:15 PM   #1
Rewards Points: 117
staircase remodel: removing riser
Hi all, I'm looking to remodel my staircase. One thing I wanted to do is to is a "floating" look. I've attached 3 images, 2 of them is my existing staircase, and the other is the look I want to create. To do this, I'm hoping to remove the riser of the stairs and remove the drywall on the backside. Can this be done? Or this is much more complicated than it appears? Will this affect the structural integrity of the stairs? Thanks!
staircase remodel: removing riser-018-staircase.jpg   staircase remodel: removing riser-34957c6cf1c74a962c2aa50931f295bf.jpg   staircase remodel: removing riser-3e33e0d2137cd2d954acb652cb6a02a1.jpg
jsunsun is offline   Reply With Quote
Old 12-11-2012, 06:54 PM   #2
An old Tradesmen
Rewards Points: 6,516
Moved to carpentry forum.
Old 12-11-2012, 07:17 PM   #3
DIY staff
Rewards Points: 7,174
I'm not a stair master---however--riser-less stairs are no longer allowed by code in the US and Canada
So tempered glass rises will be needed---or something to restrict the size to less than 4"
The insides of your risers will be 'utility grade' looking---raw plywood--glue runs--glue blocks and exposed screws---
Also exposed tread wedges might be unsightly---
A new staircase built for that treatment might be a better choice.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (12-11-2012), rossfingal (12-11-2012)
Old 12-11-2012, 07:23 PM   #4
Rewards Points: 2,238
You have to find out what the structure of the existing stairs is -
meaning - bust into the under-side of the stairs.
Check with your local code enforcement authority - to see if open "risers"
will "fly".
In some places - you can't have open "risers".
Better find someone that knows "structure".
See what they say.
To put a set of stairs in there - many thousands!!
rossfingal
rossfingal is offline   Reply With Quote
Old 12-11-2012, 07:35 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
The carriages of those two stairs are totally different. This for sure is not a DIY project as it would be really involved, unless your skill level is pretty high, even then it is iffy. Even if code allowed the open risers which it won't. Chances are once the sheet rock is removed you will see the carriage or stringers will not be dressed and several different types of fasteners and bolts will be exposed that would have to be covered, not to mention the holes in the back of the treads where the riser is fastened as well as glue. The scotia mold will leave nail holes on the underside of the front part of the tread also.The front edge of the stringers will have to be dressed someway as well.
Another thing to think of is removing and replacing all of the treads as there will be a 3/4 inch gap behind each tread by the removal of the risers.
Chances are the stairs will be more bouncy once the risers are removed also. You will have to address the exposed edge of the skirts, and if the stairs are mortised in on the wall side, you will have to cover or fill the area where the risers are mortised into the stringer. Even if they aren't mortised in, the skirts will have to be modified and refinished. You will not be able to get that complete open look with the design of the existing stairs.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-11-2012, 07:40 PM   #6
Rewards Points: 13,274
Not sure how it works in your area but here the bottom of the exposed stairs needs to be covered with 5/8 sheetrock to meet fire code.
Old 12-11-2012, 08:23 PM   #7
Jessh!
You got a really, nice set of stairs (existing) -
Why mess with something that ain't broke!?!
Don't understand!?!
Old 12-11-2012, 08:49 PM   #8
kwikfishron's Avatar
Rewards Points: 178
Originally Posted by rossfingal View Post
Jessh!
Don't understand!?!
Maybe because “cooler” is better than just “cool”.
Anything’s possible for a few more shillings.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 12-11-2012, 08:53 PM   #9
recently retired
Rewards Points: 280
Do not proceed, this is far outside the task a DIY'er should consider taking on. In addition to the things already mentioned removing the risers will greatly effect the beam load capacity of the inside stringer. Esthetics aside you would need a structural engineer to sign off on it. My recommendation would be to contact a stair shop in your area. They could make the stair then bring it to your house as a completed stair. You would have a stair built correctly and the peace of mind knowing a structural engineer certified it.
staircase remodel: removing riser-open-stringer.jpg   staircase remodel: removing riser-open-stringer-1.jpg
Keith Mathewson is offline   Reply With Quote
The Following 5 Users Say Thank You to Keith Mathewson For This Useful Post:
BigJim (12-11-2012), hand drive (12-12-2012), kwikfishron (12-11-2012), rossfingal (12-11-2012), woodworkbykirk (12-12-2012)
Old 12-11-2012, 09:04 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Beautiful work buddy.
Jim
The Following 2 Users Say Thank You to BigJim For This Useful Post:
Keith Mathewson (12-12-2012), oh'mike (12-11-2012)
Old 12-11-2012, 09:14 PM   #11
Rewards Points: 117
Thanks for all the responses! I guess I'll stop dreaming about this then. It was something I thought of but was never able to find the answers. Now I got the answers, I'll remove this thought from my DYI brain. Thanks!
The Following 4 Users Say Thank You to jsunsun For This Useful Post:
BigJim (12-12-2012), kwikfishron (12-11-2012), oh'mike (12-11-2012), rossfingal (12-11-2012)
Old 12-11-2012, 09:24 PM   #12
Nice stairs!
You're a 16th off over there, though!!
Happy Holidays!
(Thanks for stopping by!)
NICE!! Stairs! Holy Moly!
Old 12-12-2012, 08:59 PM   #13
recently retired
Rewards Points: 280
Full disclosure, I didn't build those stairs but helped a fellow stairbuilder install the curved glass balustrade. If I remember the story right when the house was built the builder intended to install it himself and hired a local stair-parts company, now out of business, to make the stair. At some point it was felt, I think by the homeowner, that he wasn't up to it and hired my friend to finish it and he asked me to help.
Drilling 2" holes on that inside stringer was a real pain.
Old 12-12-2012, 09:51 PM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Seeing several of your stairs built similar, I just took for granted that this was yours also.
Jim
Old 12-12-2012, 10:39 PM   #15
recently retired
Rewards Points: 280
Jim,
I should have said something in the first post. Funny thing I just got a set of blueprints a couple of days ago for a job so it looks like I'll be building a stair much like it, only in white oak in about 9 months.
The Following User Says Thank You to Keith Mathewson For This Useful Post:
BigJim (12-12-2012)
Removing a Second Staircase standmatt Remodeling 4 10-08-2012 11:42 PM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 07:16 PM
Concrete steps with one side against wall oxicottin Building & Construction 12 10-14-2011 03:12 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 01:58 PM
