Staircase railing
If the bottom newell is notched against the riser, the best thing is to drill a couple of holes hole with a plug counterbore, screw it with screws long enough to go through the finished riser and into the rough framing, and install plugs or buttons, depending on the finish. While the bottom newell may very well be loose , don't expect miracles here.That long a rail should have had an intermediate newell or the ballusters should have been installed with threaded baluster dowels instead of the typical crap drilled hole in the tread with the little factory turned dowel shot with a trim nail. If the newell sits completely on top of the tread, I'd use a combination of a L bracket made for newell fastening and some long screws into the tread. Install a piece of trim moulding to hide them.
