Stair Treads - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 04:40 PM   #1
stair treads
Hello
I am measuring and cutting maple stair treads.
Should i first cut the length and then measure for the width
or
should i measure for the width and then cut off for the length
thanks
john
jandrews is offline   Reply With Quote
Old 03-22-2013, 04:45 PM   #2
Rewards Points: 13,256
Cut the width then the depth so the tear out does not mess up the tread.
What are you trying to use to cut them?
You do know each one can be a little differant, right?
Going to stain them? if so concider doing it before installing so your not getting stain on the skirts and risers.
Old 03-22-2013, 05:11 PM   #3
stair treads
Hello
thanks for the advice
i think ill get them stained first and then glue them down and i have access underneth so ill have someone heavy stand and then ill screw them from the underside.
Its my first time. i was very successful in cutting them to width so i wont need to hide any imperfections as they fit snug.
The part i will need to hide is where the back of the tread meets the riser. a very small gap. Do you have any suggestions. should i try and plane the riser.
i think i will mess it up.
Also one of the boards i cut to short to width , very slight ( 2 mm ) should i caulk the skirt or putting the imperfection, or should i just bite it and spend the 60 bucks for another tread.
thanks
john
Old 03-22-2013, 07:05 PM   #4
I cut the back of the tread at a very slight angle for a tight fit.
No filler is going to fill that gap and not show.
woodworkbykirk (03-22-2013)
Old 03-23-2013, 09:36 AM   #5
Rewards Points: 196
If the tread is going to fit into a routed box stringer on the one end you can put a spacer on that end of the tread when you slide it into the stringer.
Jason34 is offline   Reply With Quote
Raising & replacing stair treads zakany Flooring 5 11-29-2012 11:51 AM
replaced stair treads dhungy Flooring 5 06-20-2012 11:21 AM
Stair treads - wood choice tradeoffs? kidtire Flooring 0 02-01-2012 06:15 PM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 11:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
